loading
Step 2: Elevate the car
Use the floor jack to lift the front and rear of your car, and place jack-stands at all four corners.  Try to elevate the car so it is level - this will ensure proper fluid levels when refilling later.
I used the tow hooks to jack up the car and then placed the jack stands under the pinch welds at all four corners.
Note: In anticipation of having all four wheels off the ground, I broke the lug nuts loose on the wheels, lifted the car, and rotated the tires.  The manual indicates switching the front to the rear and rear to front; keeping the left on the left and right on the right sides.  If you do this, remember to re-tighten the lug nuts when you lower the car.
About This Instructable
20,856views
8favorites
License:
More by ablank:Change the differential fluid in a 1999 Subaru Legacy Hand Towel Rack - I made it at TechShop
Add instructable to:
