3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Change your car's windshield - Mazda Demio 99
Change your car\
 First you need a new windshield. Urethane, spatula, hammer, gasoline, some old fabric and a helper.
1.- Remove the windshield wipers and the grill that covers the bottom of the windshield, you will see the 2 plastic bases where the windshield stands.
2.- Remove the plastic surround side and top mouldings, do it gently since the plastic can be old, you're going to use it again.
Step 1Glass detachment
Glass detachment
 Separate the glass from the urethane,  since the urethane is very strong, use a hammer and a spatula (this need to be done gently since you don't want to damage the paint)
This is where the helper is needed because he is going to tell you when to stop, when he sees the spatula blade out, he's also going to tell you where is not finished.
3 comments
Feb 28, 2012. 8:21 AMHole_In_The_Wall_Laboratoy says:
I was an auto glass specialist for over 10 years and this type of work takes lots of practice. One little mistake setting in the glass can be expensive and MESSY.
My advice is leave it to the professional.
Dec 5, 2011. 12:03 PMrseiter1 says:
This is NOT a job for an amateur today's cars need the WS installed correctly in order to keep you safe and or alive, I almost choacked seeing the hammer and chisel removal method. almost any auto parts store sells the correct cutout tool for about 20$ and once the molding are off it you can just the WS out in less than 10 min (for an amateur ). If I need to save a life i could rip the molding off with my bare hands and use a cold knife and have it out in less than 3 min, Much faster than the Fire Dept.
you need to consider urethane OEM is best and strongest you could physically use Dap 33 or crazy glue but if you roll your car you may end up dead.
Leave this job to the Pros, to get insurance jobs they HAVE to offer a lifetime warranty against defects in the glass and workmanship, if your buddy installs your WS with Elmers glue and it leaks and you get hurt , who can you blame, if a reputable glass co does it then you are much much better off. Even if you cannot afford new class buy a junk yard WS and have a Pro put it in,
This could be a life or death mistake doing it yourself
May 25, 2011. 8:26 PMIvan Denisovitch says:
Looks simple enough. Pick n Pull wrecking yards are half price this weekend, so I think I'll try and find a good replacement for the cracked windshield in my 84 Tercel wagon. Thanks for the 'ible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:danleano
