Welcome my fellow auto DIYer. First, I commend you for taking on this task, I will rank this as one of the more difficult things in the realm of the 'shade tree' DIYer. The hardest thing to deal with is tight spaces, other than that the task is straitfoward for the most part
Remove these ads by
Signing UpStep 1Background Parts and Tools
I did not have to replace my T-belt, my water pump died and because replacement involves removing the T-belt, I did so as a precaution.
Tools and Parts:
# New Timing Belt
# New (or reman) Water Pump
# Tensioner Spring
# Tensioner Pulley (if higher mileage)*
# Idler Pulley (If VERY high mileage) *
# VC Gasket*
# Gasket Scrapper
# Torque Wrench **
# Jack, Stands, Wood Blocks
# Black RTV sealant (I do not recommend "Ultra Black")
# Metric Allen/hex Key set (Or 1/4" - may require sanding to fit)
# Plastic Baggies and Sharpie
# Piece of Cardboard
# Feeler Gauge Set ***
*If you have the ability, wait and see if the old one is still good - I changed at 74K miles. My tensioner had play in the bearing but my idler was in great shape.
** Highly recommended.
*** Perfect time to check your valve clearance for you guys with solid lifters (98+)
The 93-97 model years used hydraulic lash adjustment (HLA) as opposed to solid lifters used in the 98-2002 design. Both work just fine, but HLA's can clog easily causing valve tap. Its just cosmetic and several frequent oil changes clear it up.
I believe they are designated "interference and non interference" engines. In Certain engines like the older mazda 1.6l if your belt breaks or slips your car won't run but it won't damage anything.
I just replaced the timing belt and water pump on my Honda Pilot (3.5l VTEC). Anyone getting ready to save money by doing this themselves should be warned - the crankshaft pulley bolt does NOT want to come off! I discovered that Honda's use some type of metal or coating on the thick washer behind that bolt that essentially fuses itself to the crankshaft over time. I had to heat mine with a propane torch for about 10 minutes before I could get it to budge. Even then, I was using some pretty serious leverage to get enough tourque on the bolt. Bottom line= heat the bolt and washer before you start wasting your energy trying that bolt.
P.S. The special Honda tool sold to keep the pulley in place was useless to me. I just wedged the flywheel as suggested by Chilton's.
Hope this saves someone else some time/frustration/pain/cursing, etc...
I don't actually know what the official time is... But $35/hr is cheap :p
