Step 6Removing the VC
Picture 1:
Look at the bolts on the VC. Notice how they all have the number '6' or '9' on them (can't tell which). Well, thank you mazda for number coordinating your fasteners. If I recall, '6' (or '9') means 10mm wrench wink.gif So take your 10mm wrench and remove the bolts. Press each one into a piece of cardboard. I drew a mini picture of the top of the engine so I would not forget where to put the bolts. Some are different lengths - mark those with an 'L' just to make sure you have everything right.
Picture 2:
Tap on the VC with a rubber mallet a few times to release the bond of the gasket. Remove the breather hose and PCV. Make sure the PS hose is out of the way (you did remove the PS pump right?). Then pull the cover straight up (so you avoid hitting the cams/sprockets). I use 100% synthetic oil. The inside of the VC was a beautiful amber - only slightly darker than the oil
Add Comment
