Step 8Remove the Top right Motor Mount
iImage Information
Take a block of wood and put it on top of your jack. Lift the engine (place the jack on the oil pan) a tiny bit (as soon as you start seeing the engine going up). Using a deep well socket, unbolt the two block-mount bolts. One of the bolts has a ground, make sure to keep the washers and place the ground wire off to the side. If a stud comes up too, don't worry - just place it in the baggie. Next, remove the bolt that goes right through the whole mount/support bracket. Using a long extension is very usefull if you go UNDER the power steering hose. Remove the bolt and take the mount out by lifting up - be carefull around the a/c lines if you have them
