Chaotic shelves, quick and dirty
A very quick way to make a chaotic looking array of shelves.
This one is made of surplus pieces of hardboard + tie-wraps, but the concept can be used with many (scrap) materials.
Step 1Get your materials
Get your materials
The strength of this structure comes from the shape that the sheets make to each other. One shelf is the support for the other so to say. Every second corner is attached to the wall. The corners aren't fixed by themselves (they're just tie-wrapped), but are held firmly in place by the structure.
This way you can make a form-fixed structure without the need for sturdy joints.
What you need are three basic things:
Sheet material. Use whatever you like as long as it's strong enough for your needs. I used 3mm hardboard because i had a lot of it left. It bends when you put weight on it but it doesn't break easily.
Corner connections. Tie-wraps is definitely an easy option, but wire or rope will also do the trick.
Wall connections. Screws with a washer or something like that so you can connect a tie-wrap to it. I found some old meccano corners that were really handy for this.
11 comments
Jan 24, 2010. 4:33 AMlogghi says:
Is there a way to attach this to a wall besides screwing it on?. I ask because my bedroom wall is made of really onld crumbley plaster, so I can't nail/screw ect things to it. Spesial glue or anything? Or am i destined to a have a blank wall? Thanks.
Jan 25, 2010. 11:14 AMlogghi says:
I thought about magnetic paint, think it could work?
Jan 29, 2010. 9:54 AMlogghi says:
i agree, maybe not for shelving, but for like, posters and things? I ordered some, Im going to use it for fridge magnets and things.
Sep 13, 2009. 9:52 AMKiteman says:
They look brilliant, but how sturdy are they?
Some of those shelves are already bending in the final image...
Sep 13, 2009. 12:15 PMGorfram says:
I'm usually a lover of right angles and repetition of similar forms, but I like how these shelves visually integrate the odd bits of existing shelving into one intentionally chaotic whole. (Although I still can't help thinking that Rotterdam must be the kind of place where earthquakes are not a big worry...)
Sep 14, 2009. 5:27 AMPKM says:
Europe is the kind of place where earthquakes aren't a big worry. There's the odd bit of tectonic activity on the Mediterranean coast in the Italy/Greece/Turkey area, but continental Europe is pretty safe.
I agree with Jiskar, I'd use a stiffer material, but I like the design, and it would make me less retentive about how things are organised on the shelves if every shelf was a different height/length/angle.
Sep 13, 2009. 11:27 AMReffner says:
I like this! I wish my mind wasn't so "geometrically focused". I can't ever seem to make things look "random". Nice job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Jiskar(Jiskar)
