3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ChapStick LED Flashlight
This is an instructable on how to make a flashlight out of a ChapStick tube. After reading up on multiple LED instructables I thought it would be neat to make an original design that had not been done before. Since button cell batteries can be expensive, I went with an A23 (12V) battery that cost less than $2.00 for two.
Step 1What you'll need:
What you\
ChapStick Tube
Tactile Switch
A23 Battery (12V)
470-Ohm Resistor
10mm White LED (28,500mcd, 20mA, 3.5V)
Solder
Heat Shrink Tubing
Wire
"N" Battery Holder
J-B Weld
77 comments
1-40 of 77next »
Apr 3, 2012. 6:59 PMAdambowker98 says:
So, in step 5.... I didn't understand the instructions. Could you explain them a little better? I really want to build this.
Apr 5, 2012. 7:49 PMAdambowker98 says:
I don't understand what you are putting on the bottom and what you are doing.
Apr 6, 2012. 8:06 AMAdambowker98 says:
But what good is the plastic between the two terminals?
Dec 7, 2010. 12:24 PMstormy0314 says:
Could you use a voltage regulator instead of a resistor. I am just getting started in electronics and am not sure of all the substitutions.
Apr 6, 2012. 8:13 AMAdambowker98 says:
Maybe, but I think the resistor would work better for this project anyways considering its size.
Dec 10, 2011. 4:13 PMBasicCarl1 says:
can u use LED christmas lights? (the small ones)
Dec 22, 2011. 11:07 AMsmelly210 says:
yes it worked for me
Apr 10, 2011. 7:12 AMwireless charger led flashlight says:
Since the first flashlight was designed On January 10, 1899 by American, the
light inside the flashlight have gone through with incandescent bulb for about
100 years , In 1999 the first white led was invented, ,which was used inside the
flashlight means the New Age coming for human .
For hundred years ,except the light, the function of the flashligh has been rarely
changed, Why people are only engrossing to charge the structure and make the
flashlight looked nice??
Why don't they create really functional and convenient products??
Years of concerted efforts in wireless power,we gained greatly achievement in
this research for led lighting.The first wireless charger CREE led flashlight was
Designed in 2009.We believe that it can bring really convenient to people. It'll
become a star In flashlight field for it's convenient,durable and cost-efficient
You can view our web: http://www.wirelesspower-ledlighting.com/
Dec 22, 2011. 11:06 AMsmelly210 says:
do u like flashlights lol
Apr 16, 2011. 9:03 AMVenemot says:
Just letting you guys know a23 batteries have 8 1.5 volt button cells
Apr 3, 2011. 3:24 PMkieperm says:
This is a great project. I started to tear apart the 12v battery and putting only 3 cells together. This way I don't need a resistor and save some $$ on the battery. Now if I could find a tool the would cut the 5mm square hole for the switch I could make these a little faster for some friends and Family.
Oct 23, 2010. 9:49 PMkieperm says:
me and my daughter thought this would be a fer cool project to try out. I we are using the (http://www.radioshack.com/product/index.jsp?productId=3060978) as our switch and since it has 4 posts on it I am not 100% sure how to wire it up so it will work. Any help would be great thanks
Apr 3, 2011. 2:42 PMleggomylegoeggo says:
I believe the posts opposite each other are connected. as long as you connect posts that aren't directly opposite, it should work. http://www.flickr.com/photos/59935244@N03/5475275601/ http://www.sparkfun.com/datasheets/Components/General/00097.jpg
Mar 23, 2011. 12:44 AMFlying_MashedPotatoes says:
This might have been said already (or something similar) but what if you picked up a cheap scanning radio from the dollar store and attach the volume wheel to the spinning end of the chaptick? then you have light brightness controll; perfect for looking during the night without waking up ur wife. (lulz i dont have wife though, me only 18)
Feb 4, 2009. 7:35 PMarukaen says:
Im new to the whole electronics hobby scene. Im trying todo this as my first project. So far I've failed horribly lol. I bought 2 LEDs one that I soldered and I think in my soldering screwed it up because it wont turn on when I connect it to my electronics lab kit. Then second one turned on but blew out. -_-
Nov 10, 2010. 8:18 AMjaketheman987 says:
You need to use resistors to reduce the current flow.
Jun 17, 2010. 3:23 PMMunchys says:
Could i shrink heat shrink with a blow dryer?
Aug 9, 2010. 7:48 PMtaleya says:
You can, but you need a fairly beefy one. I've done it - if you have a salon-style hairdryer you can do it, but a cheapie one won't generate the heat.
Jun 29, 2010. 11:56 AMMunchys says:
I didnt know i could use a lighter
Jul 2, 2010. 10:09 AMRobot Lover says:
this is really cool. I was thing of this idea a few days ago, but the switch was a pot that makes the led dim. 5*
Nov 1, 2009. 3:59 PMOsiris19 says:
 Could you use a SPST switch instead so you don't have to hold it down?
Nov 3, 2009. 3:10 PMOsiris19 says:
 What type would you recommend?
Nov 6, 2009. 3:48 PMOsiris19 says:
 But, how would that work? It's rated at 250VAC and 3A. This switch would probably be better considering it's in the size range but the leads are little small.
Jun 6, 2009. 1:14 PMacgr46 says:
hey its very cool this..im new ati this things so its kind of difficult to follow some of the steps but i will try it. Where can i find the material?
Nov 6, 2009. 12:47 PMOsiris19 says:
 Radioshack.
Jul 18, 2009. 1:50 PMj574sbi says:
sell me one?
Jul 11, 2009. 4:17 PMchinchymork says:
wow what a great Instructable! I love it. I have seen this before and I just got around to making it! I did a crude job but it still works thats the main part! instead of your switch I found a momentary switch that I used it works great!
Jun 19, 2009. 12:35 PMaurorab17 says:
what kind of wire was used in this step?
Feb 23, 2009. 3:17 AMR4Man18 says:
put this into a lipstick cont and give it to the lady.... lady ada. lol
Feb 5, 2009. 11:09 AMPyroMonger says:
this is sweeeet....and convenient....and discrete..great job! 5/5
Jan 4, 2009. 4:17 PMKaylen97 says:
wow I may have just made my instructables acount today but this deserves a blue ribbonb
Aug 19, 2008. 11:46 AMchriscc63 says:
you sun of a gun I was just prepairing the exact same instructable . yours is great too.
Nov 26, 2008. 2:06 PMColonel88 says:
SUN????Heres an idea. LED DISCOBALL!!!!
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:BCat
