3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Charcoal Starter
Charcoal Starter
A "chimney" type charcoal starter, so that junk mail, found sticks etc. can take the place of lighter fluid in your barbecuing tradition. Made of two cans and a coat hanger...couldn't be much cheaper.
By the way: be very careful about fire and sharp metal. If you don't think you can handle both fire and sharp metal without hurting yourself, do not attempt to follow these instructions.
Step 1Gather Tools & Materials
Build Materials:
  • Coffee can (or other large, tin-plated steel can)
  • Coat hanger (no fuzz, plastic etc., just bare wire)
  • Small can (from olives, individual servings of pasta sauce, etc.)
  • An abundance of caution. This will be used up quickly, due to all the sharp edges and dangerous tools involved. If you lack caution, be sure to have a few units of blood and a field suture kit, instead.
Build Tools:
  • Can opener (both cut-around-the-lid and punch-a-triangular-hole)
  • Needle nose pliers
  • Tin snips, or similar (I used the black ones shown)
  • Hammer
  • Nail Um...or similar.
Use Tools & Materials:
  • Pot holder or oven mitt
  • Charcoal, or other solid fuel
  • Paper, cardboard, small wood, or other tinder/kindling
  • Matches, or a live coal stolen from the neighbors
9 comments
Jul 7, 2007. 9:53 PMits a lion says:
how about using the coat hanger itself for the legs. you could make an arrowhead shape (sorry for lack of better wording) and squeeze it together to put through the holes. that way you dont have to deal with sharp metal, and there is no way it is going to slip unless you load 15 pounds of charcoal in it and it bends... the only thing i can think of is it falling over, but your loop covers that for them too, it may just have to be a little bigger. or maybe bending the extra bits that are inside of it back through one of the nail holes and bending it over to secure it would work. perhaps i will try that and post my results. now... who around me drinks coffee... wow... i reread that, and i definitely do not have a knack for describing things.
Jul 23, 2007. 5:31 PMcalikoala says:
using a coat hanger without anything else to take the weight won't work. When the charcoal begins to get hot, it will cause the hanger to soften and the whole unit to fall over which could be a hazard. I am surprised you could use the hanger as the handle without some kind of heat shielding between the can and the handle.
Jul 8, 2007. 4:54 PMits a lion says:
well it looks like it may not work. i did manage to find a coffee can in a cabinet, but my parents kind of stopped the process short. "what are you doing with those coat hangers?" crap... since i have $0 it looks like if i do manage to make it, it will be sometime in the future after i make some money and get some new tires.
Jul 30, 2007. 9:04 PMits a lion says:
haha thanks. the 20th was my birthday, so i got some money to pay for the tires, and a little bit of spending money, so that is taken care of. and i didnt know that the coat hanger would soften as it got hot, so that probably wouldnt work. and yeah burning down the house would not be fun... and i like the "positive-net-worth project" i may have to use that some time.
Jul 6, 2007. 12:41 PMunjust says:
very nice. i made mine out of a piece of galvanized stovepipe, cutting up ~2" dividing the bottom into 8th and folding up every other piece to support the charcoal, and then cutting around and rolling a handle out of the upper portion, but this method leaves many fewer pointy bits and is better for a less skilled metal worker. also less of a need to precook it to remove the nasty galvanizing, although probably still a good idea.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:polyparadigm
