3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Charge Axim X50v from ANY USB charger + Sync problems
Recently I had a few problems with my Dell Axim X50v PDA. This PDA charges through USB, but requires a 2.0 port. This was never a problem before, that is until my computer went out and I got a new one.
For some reason the new computer would not connect to the PDA, not connecting means no charging. Yes the charging light does come on, but no charge to the battery at all.
I needed the PDA the next morning and was willing to try just about anything to get it working.
I looked up the pin outs for the connector online and noticed that the 5V+ line from the USB cable went to a couple Data ports and to the charging circuit. Since i ha 2 USB cable I decided to mod one to see if it would work. All I wanted was to charge the battery.
The end result allowed me to connect to my new computer, charge for ANY USB wall or car charger. Even homemade ones that are just a 5 volt power supply. This will also help your battery to last longer.(more charges) Because it slow charges the battery instead of fast charging.
This will work with the Del Axim X50 X50v X51 X51v models only. This is not for any other models.
With a 2200Mah extended run time battery in my X50v it takes about 6 hours to charge compared to 2 hours before this mod.
Step 1Parts
Parts
What you need for this is
USB Cable, not a cradle
small philips screw driver
Sharp Knife
11 comments
Aug 25, 2011. 5:15 PMbbear4 says:
Thanks! I am going to give it a shot. I spent $40 on a used but seemingly good condition x50v. I then had to buy a new battery because the one it came with was swollen. I also had to buy a charger/data cable because the one it came with was not the right kind.
When the new battery and cable came, I plugged them in and I got no where. I'm going to open up my charger cable and see if I can do what you have done here. It has wifi so I assume I can modify my cable and if I loose data function, I can still add files with the wireless. At this point, I'm just hoping I'm not $50+ dollars in to a damaged PDA. Damn ebay sellers saying it worked last time they tried but no returns and it's untested. I'm starting to think untested just means 'I couldn't get it to work but don't want to admit that!'
Does anyone know if the battery cover has to be on an x50v for it to charge? I misplaced my battery cover and I keep a cluttered work area.
Apr 22, 2011. 12:55 AMthelastonekills says:
hi, i was at a pc swap meet not that long ago and was a table of old pda,
they where $10 or so so i got one, its a dell axim x51v, surprisingly it wont turn on, i have a kinda charged battery for it and nothing else, any hints? or do u need a cable to turn it on or some thing?
also are they any good?
May 7, 2011. 3:44 AMthelastonekills says:
wow this is a surprize, i got it working. thks 4 the instructable it really helped, i suddenly get the charging problem
Apr 14, 2010. 12:23 AMvomov says:
 I've found that my cable only has the wires, but it has two red wires on the most left top and bottom row of pins, and three black wires roughly left of the middle. One on the top row, directly left of the middle, one directly 'below and one pin to the left', and one two pins left to that one. I am assuming this is not standard.
So, I've got a total of five cables, of which none are green or white, and no idea of how to make this into a slow-working charging cable...
Oct 2, 2009. 9:49 PMctny says:
Can you explain why the trick works? And by cutting the cable, what functionality is lost?
Sep 27, 2009. 1:16 AMefrenlugo says:
wow! it works... I had my AXIM in the trash because was not charging from USB.
Sep 10, 2009. 4:44 PMjamfire says:
I followed the directions exactly and this killed my cable. Went from turning the charge light on, but no charging unless pda had more battery power anyway, to not doing anything.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:scob89
