Introduction: Charge a Battery With a Motor or a Solar Panel!
Picture of Charge a Battery With a Motor or a Solar Panel!
Go green with your very own power generator!
Big industrial power generators make electricity by turning huge motors with coal and fossil fuels, but you can make your own with a small DC motor and some simple electrical components. I made this for fun one day because I needed a way to charge my flashlight batteries when I was away from home.
Difficulty:easy..Basic soldering
  • I used two solar panels salvaged from solar lawn lights -Lawn Lamp project from dollar general; each solar panel is roughly 1 square inch and produces 0.66 volts and 0.55 watts.
  • A cheap rechargeable AA battery needs 2.8 volts to fully charge in 12 hours.
  • 2 of my solar panels connected in parallel should take around 17 hours to charge the battery in daylight; or almost 30 hours to charge a AA battery with only 10 hours of daylight per day.
It is not very practical, but it's fun and it works in an emergency! Also, please feel free to comment and I'll try to answer any questions!
Step 1: Gather Your Parts
Picture of Gather Your Parts
Step 2: Connect Your Components
Picture of Connect Your Components
So, the motor has two leads: one goes to battery(-) and the other goes to battery(+) through a diode. The LED goes to (-) and to the switch through the resistor. For a solar panel it's basically the same deal; just look at the pictures.
Step 3: More Current (Optional)
Picture of More Current (Optional)
Connect in Parallel for more Current = faster charging
This step is pretty simple: just add another solar panel or motor and connect their (+) and (-) together using a diode, to achieve a faster charge. (look at the picture)
oskar666 (author)2016-10-03
Thank you :)
RenesasT (author)2016-05-16
Dear,
Can you please tell me, how DC motor generates Voltage.
Solar panel can generate using sunlight. But how DC motor?
millerman4487 (author)RenesasT2016-05-17
they do not do it automatically, but since you can use energy to turn the motor, you can turn the motor to produce energy. just like one of those hand crank flashlights that you power by turning it.
About This Instructable
4,346views
143favorites
License:
Bio: I go by millerman4487, and I am here to share what I make. Hopefully, you can learn from watching what I have done and even ... More »
More by millerman4487:DIY SensorsDIY Shock Sensor With a SpeakerReusing Game Controllers
Add instructable to:
