Introduction: Charger Hack in a Pinch
Picture of Charger Hack in a Pinch
Sometimes I find that I don't have the correct charger for my gear, I guess I am not organized although I know where is most of my stuff ;).
Normally I find one with the correct voltage, but the plug does not match.
Instead of going to radioshack or similar outfit to get the correct plug or charger, I do the following:
1-Cut a little piece of an old phone wire with about  3/4" and remove all the the colored wires from inside (this will be the gray sleeve to insulate the positive wire inside of the female plug).
2-Remove the insulation of 2 colored wires with about 3" long and twist the strands on itself so that they stay together.
3-Bend the edges of one of the bare wires and insert inside of the 3/4" sleeve. Slide the sleeve down the female -male pin-.
4- Twist the other one bare wire around the ground of the male plug.
5-Bend both ends of the unused bare wires and insert as shown in the photo.
I am sure someone can come up with a better setup and better description, but this quick setup works  to charge a gadget with a regular round plug without cussing, swearing or smoking.  Besides, I stopped smoking for some time now ;)
About This Instructable
986views
6favorites
License:
More by ribatejoluso:Charger hack in a pinch
Add instructable to:
