Charging Box
Introduction: Charging Box
A simple box that can be used to charge your devices
Step 1:
First of all, you will need pvc pipe and a box. Get a box about the size that you want the box to be.
Step 2: Base
Put two pipes of pvc the same width as the box you are using parallel to each other on the bottom of the box.
Step 3: Hole
Poke a hole on the top of your box and pull the power strips cord through the hole. Try to get the cord to go as far as possible so you can have the maximum amount of length.
Step 4: Power Strip
Tape or glue the power strip on the inside roof of your box. the more ports the power strip has, the more defvices you can charge at one time.
Step 5: Dividers
Use pvc pipe to make dividers inside of your box. I put one space for a laptop and two spaces for smaller devices.
Step 6: Extra Pockets
If you want to add additional places to hold small devices in your box, you can add small pockets to the inside roof of your box next to the power strip. Use pvc as the sides for the pocket, then place a sheet of cardboard on the top and side of the pipes to create a pocket.
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    That's a good way to make one out recycled materials :)
