Charging Station With Individual Switches
5,584
241
6
Published
Introduction: Charging Station With Individual Switches
Hello, here's another project of a charging station, based on various found around here, special thanks to PROD for the switches idea. It´s very basic, in terms of woodkrafting and electricity.
Step 1: Material Used
I've just used some spares around the house:
- Wine wooden box and furniture felt pads
- A piece of plywood (from the back of a frame)
- A piece of EVA foam
- Few brass gromits and pushpins
- Wire, "female" outlets, wire conectors, terminal blocks, rocker switches, a/c outlet.
- basic tools
Step 2: Preparing the Box
Picked a wine wooden box and inserted in the bottom four Tap-In Felt Furniture Pads.
Drilled a hole in the back and aplied a gromit to the A/C cable.
Didn´t made any protection on the wood, but i would like to apply in the future some varnish to give a rustic look to the box.
Step 3: Cut the Plywood, and Apply the EVA Foam
Cut the plywood and the EVA foam at the same size in a way that it can enter the box tightly. Fix the EVA foam with four pushpins to the plywood.
Apply the shelf holders further down in the front of the box , so the plywood lid stays in diagonal.
Step 4: Drill the Holes and Apply the Gormits
Drilled four holes in the EVA foam with the brass gromit itself and in the plywood with a wood drill. I've made a slot from the hole to the edge of the plywood (under the EVA) and "opened" 2 gormits so the 2 larger outlets can pass through the holes.
Step 5: The Electric Insert
Wired the female outlets to each other and to the switches.
Tested outside the box.
Step 6: Drill the Switches Holes
Drilling and filing...
Step 7: Insert the Electric Inside the Box, Connect to the Switches, A/C Cord
Bad pictures... just a knot in the A/C cord so it cant be pulled from the outside.
Step 8: That's It!
Finished! Nice good looking charging station for portable apliances (nokia charger, 1 x mini usb , 2 x micro usb).
In conclusion, e realize that the box is unnecessary to high and would look much better with a rustic finish.
The major problem was the switches rectangular holes, a lot of filing...
The next fase will be apply an A/C inlet at the side of the box, just as ejpierle did so well.
Sorry for the english (not native). Any doubt just ask!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    Hello, just a wireless keyboard to use with Raspberry Pi.
    Really nice and simple! :D Could you maybe put the top cover a bit lower? In this way your devices would be a bit more inside the box and would be protected. And the box would not be "unnecessary high" as you said. :)
    Yes that's a good solution, thanks for the idea!
    Nice, and fine English! Thank you for sharing this great project!
