Charging a Gameboy Advance Sp With No Charger
61,595
31
9
Published
Introduction: Charging a Gameboy Advance Sp With No Charger
In this instructable I'm going to teach you how to charge a GameBoy Advance SP without a charger.
I made a GBA SP charger using household items. I was looking to solve this problem with a tutorial online but at the end all the "tutorials" did was tell me to buy a charger online. I figured out how to solve it and I wanted it to be shared.
This is my first instructable. Sorry for any spelling errors.
Step 1: What You'll Need
Bobby pins x 2
USB cable x 1 (Any USB cable will do)
Step 2: Putting Stuff Together
1. Peel one end of the USB cable (Don´t peel the end that will be conected to your computer)
2. Scrape both ends of the bobby pin (The round part and the flat part)
3.Tangle the positive wire to the round part of a bobby pin and the negative wire to the round part of the other bobby pin
Step 3: Connect the Bobby Pins
4.Then connect your USB cable to your cellphone charger/PC.
5.Connect the red wire bobby pin to the inferior right pin (number 3 in the diagram) on your GBA.
6.Finally connect the black wire bobby pin to the inferior left pin (number 6 in the diagram) on your GBA.
I hapenned to have a USB cable charger thingy so mine turned out like in the picture, but it will work the way I described this instructable to you.
    • Microcontroller Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    9 Comments
    This is really helpful bcs my brother broke my charger and i needed something that will do the job.... thanks i hope it works.
    when i put it in my gameboy sp charges for a few seconds then it stops. I cant put the red cord with the bobby pin all the way in. It stops when i try an put it fully in. Do i replace the bobby pin? it was like that for 3 chargers
    please help
    i can't get it to work and I tryed with 2 different usb cables...
    Would a USB 2.0 type A to USB 2.0 Micro-B 5 pin cable work?
    does work on paper clip
    You know, this is a good invention. And when I grow up I want to be an inventor, and just recently I've been told that I could sell my inventions or give them away for free. So since this invention is good, you should call a company and ask them to sell it for you
    Thanks you, and please be an inventor. Be as creative as you can. :)
