Step 2Disclaimer for bad design practices
Here I'm not using any resistors since the display is connected to the output pins of a microcontroller that normally can't sink or source more than a few times the current the leds/displays can handle continuously. Since we're multiplexing the displays they will only be on for 1/6'th of the time and can handle much more current than if they were on all the time.
In the following schematics and in my construction I've left out the current limiting resistors, both for the leds themselves and also the base resistor for the transistors.
Please note the following
It is a really bad construction practice to skip the current limiting and rely on luck and that duty cycle combined with the relatively low sink capability of the processor and the probable underrating of the leds maximum specs.
In anything that you do professionally, or just want to keep running for an extended period of time (longer than your first test run) one should adhere to good construction practices, read the datasheets and to the maths.
And read rgbphils comment about running leds over the rated current in the comments section of this instrucatble.
comment
Add Comment
circuitmage
says:
Add Comment
