Introduction: Chat by Using Websocket on WIZwiki-W7500 Platform
Recently WIZwiki-W7500 platform was announced by WIZnet. So I implemented a firmware of WIZwiki-W7500 by changing UART definition because I can handle a source code easily.
You can know www.mbed.org site. Please refer to the following step.
Step 1: Prepare Materials
Please refer to the following.
1. WIZwiki-W7500 board x2. ( http://www.shopwiznet.com/wizwiki-7500 )
2. Mini USB cable
3. LAN cable
Step 2: Hardware Connection
Please connect an USB cable and LAN cable.
You can get more HW info by the following site.
http://wizwiki.net/wiki/doku.php?id=products:wizwiki_w7500:start
Step 3: Prepare Development Environment
I prepared cloud development environment by the following site.
https://developer.mbed.org/getting-started/
# Reference
WIZwiki-W7500 example source : https://developer.mbed.org/platforms/WIZwiki-W7500/
WIZwiki-W7500 library source : https://developer.mbed.org/teams/WIZnet/code/WIZnetInterface/
Step 4: Software : Mbed Repository
I opened source codes of this project in mbed site.
https://developer.mbed.org/users/bingdo/code/WebSocketClient_Chat_WIZwiki-W7500/
You can import this project files into your workspace.
You must modify source codes for this test. (MAC address, websocket server IP & port)
After compile, you can run an application of WIZwiki-W7500.
This project is open for everyone. I expect your participation to improve a quality of project.
# Reference
Websocket Server example : https://github.com/bingdo/ChatDemoWithWebSocket
Step 5: How to Run : Test Result
1. To modify MAC address and websocket server IP & port as your case.
2. To compile a project in cloud.
3. To program FW into targets.
4. To run Websocket server on your PC.
5. To activate each connection with serial terminal.
6. To reset targets.
7. To insert chat messages after connecting with websocket server.
You can see the test result.
Thank you for your attention.
*Tip : If you register in www.wiznetian.com and work actively, you can get a sample cheaper than E-sales as well as a free sample.
