3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chauvet Hurricane 700 MOD
For the mobile DJ on a budget, the Chauvet Hurricane 700 is a great starter fogger for your setup. It is small and portable, puts out 1500 cfm of fog, has a wired remote, a 0.6L tank capacity and is $20 cheaper than the next model up, the Hurricane 900. But although the Hurricane 700 is cheaper, it lacks a key feature that the other more expensive Hurricane models have. A blue LED tank light so that you can monitor the amount of fog fluid in your tank in the dark.
So in this instructable, I will show you how to wire a Blue 5mm LED to your Hurricane 700 fogger and light up your fog tank!
NOTE: THIS MODIFICATION WILL VOID YOUR WARRANTY! I WILL NOT BE HELD RESPONSIBLE FOR THE VOIDING OF YOUR WARRANTY NOR ANY DAMAGE THAT MAY OCCUR FROM THIS MOD.
Step 1Materials Needed
Materials Needed
What you need:
Materials:
1 Chauvet Hurricane 700 Fog Machine
1 Blue 5mm Super Bright LED
1 Unused Wall Charger (Rectifier) Note: the plug should read "Input: 120VAC Output 3-5VDC" If the VDC output is greater than 5V, your LED may explode.
1 3" Piece of Red Stranded Wire
1 3" Piece of Black Stranded Wire
Tools:
1 Wire Stripper
1 Hot Glue Gun
1 Soldering Iron
1 Roll of Solder
1 Hammer or Dremel
1 Set of Heat Shrink
1 Wire Cutter
1 De-soldering Tool
1 Exacto Knife
1 Small Scissor
1 Screw Driver
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:C7mb
