This thing was on a robot of mine (http://www.instructables.com/id/EDZ6HPOMV5ET9K6IL7/) for several hours and the robot drove around a small pen. The sensors worked flawlessly the whole time, detected every bump and never got bent out of shape.
Remove these ads by
Signing UpStep 1Do It
buy some papermate mechanical pencils (as in picture #1)
snap the tip off of one.
yank out the spring (picture #2)
Solder an insulated electrical wire to one end.
get some pipette tips (this is what I used but any number of things could be used) as in picture #3
Get a thin (should fit inside the spring) stiff metal rod. I used a thin metal rod from a broken umbrella I found on the street. Solder an insulated electrical wire to one end (picture #4).
Stick the nonsoldered rod end through the pipette so that about half an inch protrudes (picture #5)
Stick the pipette/rod into the spring and bend the metal rod so that its tip touches the spring around it, and glue the pipette/rod base the the base of the spring (picture #6).
Connect the sensor to your microcomputer as seen in the diagram (last picture). The arrow symbol is the bump sensor (a switch).
You're done.
NOTE: this is a 'normally closed' bump sensor, so your microcontroller program should be waiting for a 0 (logic low) on its IO pin to signify a bump.
12
comments
Add Comment
CameronSS
says:
CameronSS
says:
leevonk (author)
says:
leevonk (author)
says:
leevonk (author)
says:
Add Comment
