DISCLAIMER: This is a WEAPON and is not for just throwing around at people, pets etc. It can SERIOUSLY injure or even KILL somebody. The blades are extremely SHARP. I am not responsible for anything that you do with this. If you are foolish enough to throw it at a person or a pet then just stop reading now.
Have fun and BE SAFE!!
Remove these ads by
Signing UpStep 1Getting the stuff
-A metal plate of some sort, relatively thick. It should be no larger than 5 inches or you will waste a lot of material. I used a galvanized steel electrical box cover I got from home depot for about $0.60. This works VERY well.
-An angle tool, or something that can measure and draw straight lines exactly perpendicular to the sides of the plate
-A pencil
-A jigsaw OR:
-A hacksaw with steel cutting blades (much slower and harder)
-If a jigsaw, high speed steel cutting blades. A pack of 3 cost me about 5 bucks.
-A bench grinder or equivalent (steel belt grinder, dremel, etc)
-3/8" steel drill bit. Mine was a zirconium coated bit from a big set my dad got. You could also buy a cobalt bit, but a 3/8" one would run you about $10. Ouch
-A drill that can run at least 800 RPM, hopefully with a lot of torque
-Metal file
-240 grit metal sanding sand paper (needed to make the pencil marks show up on the plate)
OPTIONAL:
-A drill press (I didn't have one so I was just careful. It isn't vital for the holes to be that precise)
-Some silicon carbide metal sandpaper (60, 120, 240, and if you want it really smooth, 400 and/or even 600 grit paper. Whatever you want to do.
o.
This looks kinda like a metal handle with a sharp pin coming out of it, and it's sprung load so that it will 'click' when you press it all the way down, creating a small dent in the metal.
Should be easy to find at any hardware store.
as a note, when you super heat the metal...(lets just say anything too hot to handle with with thin gloves or bare hands) if the metal is dunked into a water bath (quenched) it has become much harder...in a cool natural state, the molecules of the metal are in a Body Centered Cubic (BCC) pattern, which is very structurally stable. when heated, the molecules transform into Face Centered Cubic (FCC)...if allowed to cool slowly over time, the material will return to its original structure, if quenched the molecules will the shape of the Body Centered Tetragonal (BCT)...this is where the weakness comes from...the larger molecular structure adds hardness, and like you mentioned brittleness...if you want to fix this all you have to do is heat the metal up and allow it to cool slowly over time...this is called annealing
yet another note...you are using galvanized steel...who cares?? if you had cobalt tool steel, then you worry about heat effects on the metal...other wise, it was a good instructable, and keep having fun!
used an electric panel for the blade and some sheet metal to hold the 2 parts together.
Gonna stick it in my forge and try to smelt them all together soon.
or draw a template on graph paper like i did.
I really wish you people would quit these pointless, immature and irresponsible discussions on how to make poison to put on homemade weapons. You might as well be asking "Hey, leik how do i make a nerve agent??" or "Do you kno where i can getz sum anthrax? It wud be kewl to have some lol"
It just seems like you people haven't used your brain to make the connection between POISON and DEATH, or what death is
This post is 2 years old. I'm pretty sure that I don't need poison anymore, and if I do, I already have some.
I know many people on the internet seem stupid, but at least check their background before assuming people don't have any credibility.
Well... I'm glad we got a few things cleared up.
I rarely see a comment about the actual instructable anymore; its always about making poison ;_; and it's spamming and cluttering the comments section.
Also, i dont know how a 2 year old post appeared above the most recent comment...
No problem about the misunderstanding, happens to the best of us.
You should just turn your email notifications off.
They wouldn't give them to kids if that was the case..
www.snopes.com/food/warnings/apples.asp
