3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap, good quality Shuriken throwing star
Step 3Drawing the base square
Find two touching sides that are perfectly flat. If all of them are flat, then just pick a top and a side and scribble close to the very edge. Only put the flat of the right angle tool on these sides and only measure from these two sides. Now measure and draw a 2 1/2 inch square in the very center of the plate. For example, on my 4 inch plate, I had to measure in 3/4 of an inch in from the edge and drew a line. Then I measured 2 1/2 inches farther and drew a line there. So now I have 2 parallel lines that are 2 1/2 inches apart. Repeat this in the other direction and you will have a perfect square. Now, find the midpoint of each side of the square and mark them. Now draw a straight line between them. You should now have 4 small squares. The picture can better show what I mean.
2 comments
May 16, 2010. 1:19 PMShadowofaNinja says:
oh i didnt follow this step, mine failed... :(
Apr 20, 2010. 4:29 PMDestroyerOfWorlds says:
 Umm, just curious...what do you mean by "Find two side that are perfectly flat"
May 3, 2010. 7:29 PMSpeedmite says:
edges.
or draw a template on graph paper like i did.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Andyman3k
