3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap, good quality Shuriken throwing star
Step 5Drilling the holes (optional but looks way cooler)
Now if you have a drill press, this step will be a breeze. If not, then, like me, you just have to be careful. You are going to be drilling at inside star points. It's kind of hard to explain, so look at the image for reference. You are going to use the 3/8" drill bit for these holes. If you don't have a drill press, it would probably be easier if you use a bit about half the size to drill a hole first. It's hard to get a big bit to go exactly where you want in one shot. You can be more precise with smaller bits. Also, if you want to counter any wind blowing it off target, drill a hole in the center.
2 comments
Jun 10, 2011. 1:02 AMfkhalsa says:
Using a metal punch will help your bit stay centered.
This looks kinda like a metal handle with a sharp pin coming out of it, and it's sprung load so that it will 'click' when you press it all the way down, creating a small dent in the metal.
Should be easy to find at any hardware store.
Jun 1, 2010. 11:09 AMthe_burrito_master says:
If you make the square on a  45* angle then you can make them bigger.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Andyman3k
