3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap & Easy Giant Spider Illusion
Step 2Creating the legs
creating the legs
First take your piece of plywood and begin spraying lines of 3 different lengths (long, medium and short) for each segment of a leg. You can do all 8 legs or you can just do a few, it just depends on how you are going to display it. (**Note that in the pic in the Intro there are only 4 legs showing but in the final pic there are 6 legs)
Once the segments are dry, take a putty knife/spatula and sliding it between the foam and the plywood. It should come off fairly easy.
Next take a long and medium section and insert it into the center of the end of each piece. Don't glue it yet. You want to bend the segments, at the wire into the position you want. Cut off any pieces that keep them from being flush against each other.
When you have them the way you want, remove the wire and put some glue on the ends and re-insert them into the ends. If you use a hot glue gun let it cool a bit before you insert it or you may melt the foam. Now do the same with the smaller segment.
Once you have them together take a piece of bamboo, a heavy piece of wire or whatever you want to use to stake them into the ground with and glue it in the bottom end of the longest segment. (The stakes help in the painting process too. If you paint them outside, you can stake them into the ground or if you do them inside you can stake them into a bucket of sand so that you can paint them in one shot)
They are ready to paint now. I used black latex paint but feel free to make your spider legs any color you like. (Do NOT use spray paint unless you first paint the foam with a latex primer. The spray paint will eat away the foam.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:PaHalloweenFreak
I am a Halloween freak!! I love everything creepy & spooky about it. My favorite Halloween things are skulls, skeletons, spiders, cobwebs, gargoyles, bats, vampires and creepy dolls.
