Cheap Airsoft Red•Dot Sight
Published
Introduction: Cheap Airsoft Red•Dot Sight
Step 1: Collect You Materials
ruler, scissors, electrical tape, clear string, small led light, red bead, toilet paper roll (empty)
Step 2: Start Cutting
Make about a 2 inch square with electrical tape, cut a hole in the middle.
Step 3: Start Taping
Tape all the edges of the square on the toilet paper holder.
Step 4: Keep Taping
Tape all the way around the top of toilet paper roll.
Step 5: Poke a Hole
Poke a hole big enough to put the end of your light in.
Step 6: Put You Light In
Then put your light in the hole and tape it on.
Step 7: More Taping
Tape the toilet paper roll all the way around, make sure to tape the light too.
Step 8: Poke More Holes
Poke holes on both sides of the toilet paper roll.(make one hole big enough to fit your bead in)
Step 9: Put Your Bead On
Put your bead on the clear string, keep louping it around the bead so it stays.
Step 10: Put Bead In
Put the string through the holes and make sure its center. Once you put it through tape the string on the outside down.
Step 11: Your Done
Tape the scope to your gun and your done. ENJOY
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    Cool. You should try making one with a laser pointer!
    GM
