Introduction: Arduino Wireless Mailbox Detector Device
If you are anything like me, you look forward to the mailbox arriving like a kid nervously waiting for his presents on Christmas Eve. Since the time my mailbox arrives is not always consistent, I checked my mail multiple times a day. To solve this problem, I created a wireless sensor that tells you whether there is mail in the comfort of your own home.
Here's how it works:
The transmitter will sit under the mailbox and when the door is opened it will send a signal to the receiver telling it the door has opened ( indicating that the mailman has put the mail in). The receiver will then light up a LED indicating that the door has been opened and that's it!
Step 1: Parts and Tools
Mailbox Detection Sensor:
- Arduino with 3.3v output
- nRF24L01+ Wireless Transceiver $6 (for two at Amazon)
- Breadboard and Cables
- Reed Switch $1.50 Sparkfun
- Magnet $1 Sparkfun
- Power Supplies ( I used 4 AA)
- Tape, Velcro or double side sticky tape to mount receiver
Receiver
- LED
- 330ohm resistor
- Power Supplies ( I used 6 AA)
Step 2: Hooking Up the Arduino to the Wireless Module
First, we have to get the Arduinos to talk to each other. Start by hooking one nRF24L01 module to EACH arduino following the image above. Make sure you hook up VCC to 3.3v on the Arduino and not the 5v pin or else the module might burn up!
Once you have made the connection, we will then hook up the indicator LED and the door sensor!
Step 3: Wiring the Door Sensor and Indicator LED
Transmitter:
We will detect when the mailbox door is opened by using a reed switch and a neodymium magnet. A reed switch is an electrical switch operated by an applied magnetic field. This switch is normal open when there is no connection and closes to make an electrical connection when a magnetic field is applied.
In our application, when the magnet gets close to the reed switch by the mailbox door opening, it will create a connection between pin four and ground. This will tell the Arduino that the door has been opened.
On one Arduino connect one side of the reed switch to GND the other side to pin 4. This will be your transmitter.
Receiver:
Now we will hook up the indicator light on the receiver. On the other Arduino (not the one you just connected the reed switch to), connect pin 4 to a the 330ohm resistor to the positive lead on the led(the longer one) and then the remaining pin of the led to ground like the diagram above.
This will be the LED that lights up when mail has been received.
Now on to uploading the code.
Step 4: Uploading the Code
Now we will upload the code to both Arduinos.
Download the Arduino IDE if you haven't so already and download Mailbox_Reciver and Mailbox_Detector.
Upload Mailbox_Reciver to the Receiver ( the one with the LED)
and
Upload Mailbox_Detector to the Transmitter ( the one with the Reed Switch)
Grab the magnet, bring it close to the reed switch and see if the light on the other Arduino turns on. If it does, you did it! Woo hoo! If not, check your wiring and try again
Step 5: Mounting the Transmitter
Now its time to mount the transmitter to the mailbox.
The reed switch and magnet activate when they are less than half an inch away from each other. So, when the magnet is more than half an inch away it will say the mailbox is on and when its less than half an inch away the sensor will say the door is open.
Mount your reed switch so that it is over half an inch away from the magnet when it is the mailbox is closed and less then that when the door is open. Refer to the pictures above, and yes I did remove my mailbox so I could take a picture for you gals and guys ;P
And that's it!
Step 6: Future Upgrades
Since this is my first Instructable I wanted to keep it as short and simple as possible. This means that there is room to make improvements. So let me know what you guys think, your suggestions and I might include it in a future update ;)
Remote Control Contest
Microcontroller Contest
