Cheap Battery holder and switch
 by Dr KAZ
In this short instructable we will create a battery holder which also acts as a switch. It is portable, lightweight and uses no special techniques to create. The design is generic i.e. you may use any size syringe and combination of cells to create you battery. Say you want to have 12V then just tape together 8 x 1.5V button cells and fit them inside the syringe.
Step 1: Materials required
The cell with the voltage you need.
A suitable syringe (discarded or brand new, big enough in diameter to fit the battery you need to use or have constructed.
Electrical wire (Thin enough to fit two strands through the front opening of the syringe).
2 x nuts to fit into the syringe. These will be used as contacts.
Glue gun, scissors, wire stripper.
addinar says: Apr 15, 2013. 8:39 AM
Brillant! It is SO simple. Why didn't I think of this?
Macgyver007 says: Mar 30, 2010. 1:12 AM
Really simple but ingenious idea!
Nice! and useful just when I needed it !
Patented says: Dec 7, 2009. 3:04 PM
Nice! useful when needed !
Dr. dB says: Oct 22, 2009. 12:59 AM
A strange but ingenious idea!
In some syringes, if you pop the rubber seal off the plunger entirely, the right size nut might just screw right on to the mounting "stud" left behind...
stephenniall says: Sep 17, 2009. 2:34 PM
Really simple but great idea
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
