Cheap Braille Embosser (La Picoreuse)
1,437
21
Published
Introduction: Cheap Braille Embosser (La Picoreuse)
Presentation
"La Picoreuse" is a cheap (75€), easy to build A4 braille embosser.
This project aims to serve as a first step or a basis for reflection for other makers in order to provide an alternative to very expensive market embossers (3000€)
The idea of this project is borned to respond to the needs of the ParACheval association
The cutting and soldering part could be realized thanks to fablab-sud31 (Cintegabelle)
Sources
OpenSCAD Sketch and DXF files: thingiverse
All source files: github
Step 1: Presentation
Step 2: Components (≈ 75€)
Frame
Motors
Electronic
Step 3: Prepare Boards
Cut frame
Download the 2 files and cut them using laser cutter (cnc may broke some of the small parts)
Indicative laser cutter settings (100W laser cutter)
  • for 6mm MDF: 13m/s at 80% power
  • for 3mm MDF: 30m/s at 80% power
If you are looking for up-to-date files or if you need to adapt them to a particular purpose, you could download OpenScad sources here
Step 4: Prepare Board
Prepare boards
Sand the boards G and E and fix 5mm bolt to E board (could be done later)
G is sanded to avoid blocking the paper
E is sanded to avoid blocking solenoid wires
Step 5: Adjust the Belt Length
Adjust the length of the belt
Block one of the ends of the belt with a nylon cable tie (make sure to put the head of the collar in the plane of the belt)
Follow the path indicated on the picture attached to the belt (put 2 nuts on the big axis to be sure to have the right dimension)
Attach the second end with a nylon cable tie
Step 6: Assemble Solenoid Support
Assemble the solenoid support
Attach belt connexion bold on each side of the solenoid.
Attach bronze ring with nylon cable tie.
Attach Solenoid with bolt. Be carrefull, if the bolt is too long it may cramp the solenoid moves a bit. If so add some rings to reduce the thread length
If the belt is already at the correct length you could add it at this step.
Step 7: Assemble Main Frame
Assemble main frame
Screw the Arduino card to the board H
Embed boards F, G and H in board B
Embed board C
Slide board F so that it blocks both sides
Step 8: Leaf Drive System
Leaf drive system
Nest the leaf drive system
Notice: If your leaf drive system is not the same size, you may have to adapt board G in OpenScad sketch (here)
Step 9: ​Damping Rubber
Damping Rubber
Insert the damping rubber of the punching system. To increase rigidity it could be useful to glue last layers of rubbers togethers.
Step 10: Connectors
12v connector
Add 12v connector on C board
End-of-travel switch
Add end-of-travel switch to C board. To build a more secure machine, it is also possible to add an other switch to B board.
Notice: in the video it is added to B board because it is another version of the machine
Step 11: Buid X Axis
Build X axis
Add D board on right side.
Slide the 6mm metal bars starting with the bottom one.
Step 12: Install Belt
Install the strap and make it protrude into the notches on each side
Step 13: Electronic
Connect wires as shown in the shema.
It may be useful to use pluggable connectors for solenoid and end-of-travel switch.
Step 14: Add Electronic
Connect electronic
    Plug motor shield to Arduino board
    Pass Y motor wires throw C and D boards holes (the X motor wires must stay in)
    Add solenoid control part
    Screw the power wire (motor shield and solenoid control part togethers)
    Step 15: Finish Frame Assembly
    Finish frame assembly
      Insert board I on the back (the one with holes)
      Embed board A on the left side
      Slot board E without forcing. If it stucks, make sure to run the Y motor wires at the back of the board E, to achieve this, just pull the wires a bit up from the inside of the electronics part.
      Step 16: Mount X Stepper Motor
      Mount the X stepper motor sideways to include the belt
      To hide wires, the connector must be embedded in board A
      Connect wires from the inside once the engine is in place.
      Step 17: Mount Y Stepper Motor
      Insert the bronze ring on B board
      Insert 8mm metal rod
      Add 8mm to 5mm connector
      Add Y stepper motor
      Tighten stepper and connector screws
      Step 18: Load Arduino Sketch
      Download
        BraillePrinter.ino (file on bottom) or up-to-date version here
        Adafruit motor lib
        Step 19: Run the Braille Printer!
        1. Connect USB to PC
        2. Plug 12v power supply
        3. Insert a A4 sheet (160g should be good)
        4. Open Arduino Serial Monitor and type
        { abcdefghij# klmnopqrst#uvwxyz
        • { : initialisation
        • # : start a new line (because, on serial tool, return validate sending instead of including newline char)
        • a..z : char convert to 6 dot braille
        Rq1: The syntax should be updated in future version to include configuration
        Rq2: This is a old video version (TODO: update it)
          • Woodworking Contest
            Woodworking Contest
          • Oil Contest
            Oil Contest
          • Clocks Contest
            Clocks Contest
