3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Canvas
Cheap Canvas
Cheap canvas for artists on a budget. I also like to make canvases on a frame but I didnt have the wood or canvas for it.
Materials:
Piece of wood or something hard
Scrap fabric(mine was an apron I found)
Glue
Paint Brush or something to spread the glue evenly
Stapler
Paint
Materials Cost: High: $2-5
Low: Free
Time Cost: High: 30 mins
Low: 15 mins
Step 1Staple it
Staple it
Staple one side of the board
11 comments
Sep 16, 2010. 10:17 AMChris Bilton says:
these are excellent sugestions, well done everyone
May 21, 2009. 3:58 PMambdukias66 says:
good idea ;) i just recently tried using some canvas drop cloth i picked up at a local big box home improvement store. a 9x12 peice was about half the price of a comparable weave canvas in the dick blick catalog. for frames i've just been stapling the canvas to junk store or trash picked picture frames. and instead of expensive gesso i use either flat white latex wall paint or primer. interior or exterior is fine. whichever happens to be cheaper ;) lol! i now have ten canvasses and have painted four already, two of the unfinished are 40x40 and i still have a little canvas left over. i guess i better get painting ;)
May 11, 2009. 6:22 AMWeissensteinburg says:
Would bleaching the canvas have the same effect, or would it not turn out as white?
May 11, 2009. 11:49 AMinventorjack says:
I've never been very good in chemistry, so someone might need to correct me, but wouldn't bleach cause the art to deteriorate more quickly? I don't know what pH bleach is, but I know fine art materials are acid-free to prevent deterioration. Can anyone else shed light on this?
May 11, 2009. 3:30 PMlemonie says:
Bleach is basic, contains some amount of caustic soda. L
May 12, 2009. 12:11 AMlemonie says:
Bleaching and making white are the same thing in this case - I was answering inverntorjack with respect to pH.
L
Jan 9, 2010. 7:59 PMcvianna1 says:
Actually you are partially correct. Gesso is used to seal the canvas and create a surface that the paint will adhere to and last over time. But the white color is a matter of personal preference. You can add pigment to the Gesso to create a toned canvas, or you can lay a thin transparent layer of paint over the Gesso to tone your canvas. But keep in mind most paint is by its nature translucent and becomes more so with time.
You do not want to use bleach or other strong chemicals because they can interact with your paints and sunlight, causing color shifts, fading and yellowing. (although some artists have been known to rub their paintings with onion skins and then thoroughly cleaning between glazing coats (oil painting) to increase adhesion between paint layers.)
May 11, 2009. 9:31 AMcrampedyogapositions says:
where would you get the thick canvas matterial?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:jianqiang
I like to make things. Either out of necessity, being cheap, or just because I can.
