Cheap DIY LASER ALARM - Multi Functional!
Published
Introduction: Cheap DIY LASER ALARM - Multi Functional!
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I ma...
Hello peepz, I created a little laser alarm from a laser Emitter and a Laser receiver.
I used the ky-008 laser and the laser receiver i used is called ky-008-2 on my website.
Officially it is not called ky-008-2 but any receiver will do.
This device is multi functional, i left some ideas in the code.
Check the next step for the schematic and code.
The code is just a basic code but from here you can build many cool stuff.
So with the code you got the basics.
Step 1: The Schematic, Parts List and Code.
Just wire it up like the schematic and it should work after uploading the code.
Parts list:
  1. Arduino Uno, (I used a copy which has 7 analog pins, a quality new model from 2016 called RobotDyn Uno.)
  2. 1 Channel relay ky-019
  3. Laser Sender ky-008
  4. Laser receiver ky-008-2 (i used ky-008-2 on my website as product code, i dont know the official code)
  5. buzzer
  6. 7 color led ky-034
  7. A set of Jumper wires. MM / FF / FM
  8. A power cable and a lamp fitting + lamp connected to the relay (optional)
Succes!
Create something cool and show me in the comments!
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
