In this Instructable, you will learn how to make an SD card socket that plugs right into a breadboard for less than two dollars in parts (depending on how you get them of course). I show you how to use a simple straight pin header and modify it so you can plug in an SD card and attach it directly to a breadboard for data logging and prototyping. This is quick and easy so you don't have to wait for a socket in the mail, or build/buy the SMD breakout board for it either.
Basic soldering skills and common tools are required.
I will cover how to make vertical and right angle sockets. Either 7 or 8 pin should work. 9 pin may require some modifications, I only used 7.
Remove these ads by
Signing UpStep 1Gather tools and materials
Solder
Soldering Iron, I use 45 watt but this is more than enough
Needlenose pliers
a vise is very useful to keep from burning yourself
and at least 21 pins of straight male breakaway header pins
I got the header pins from my local electronics parts shop. Radioshack doesn't carry them as far as I know, but they can be ordered from various places around the internet for very cheap. It was 2 dollars for 40 pins at my local shop.
Here is the digikey part, it's a bit more that 2 dollars. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A26513-40-ND
Same thing from Sparkfun
http://www.sparkfun.com/commerce/product_info.php?products_id=116
These are straight male breakaway header pins.
You could theoretically use right angle as well, but I used straight pins.
Also, its real cheap!
You would not hapend to know what the protocol to use?
You are right to hold the pins in a metal vice in step 5, so that the excess heat from the soldering operation can be dissipated, lest the plastic melts into a gloopy mess. (Past, failed experiences have taught me this!)
