Step 3Bend contact pins
Take one of the 3 header rows and place it in a vise, or a pair of pliers or vise grips. I held the short end of the pins to keep them from pulling out of the plastic.
Using the needle nose pliers, bend the pins just a bit at the base, so that the tip of the pin is about vertical with the edge of the plastic. See pictures for detail. Not all the pins need to be perfectly aligned. Bend them all against a table or flat surface to line them up better.
Now they need to be bent back on the tip so it is easy to insert the card. Again with the needle nose pliers, grip just a small amount and bend it back the other direction. Do this for all the pins. See picture for detail.
Add Comment
