One of the most commonly incorporated parts to be found in these designs are Dremel-brand handheld tools, using router bits, attached to the Z-Axis. Well, I took a look at Dremel tools, at my local hardware store, Wal-Mart store, Target store, and a few other places, but I've found that they're all very expensive, for use in my upcoming project.
Well, I tackled this problem today. I built my "router" on an arm that will be attached to the Z-Axis on my CNC machine. Hopefully, others could use a similar tool, and will find this interesting.
Remove these ads by
Signing UpStep 1Tools Required
1/8" Steel-Cutting Drill Bit
3/32" Steel-Cutting Drill Bit
#4-40 SAE Tap
#1 Philips Screwdriver
#2 Philips Screwdriver
Needle-Nose Pliers
Pipe Cutter
Tin Snips
Looks like it'll be for a gantry style mill/router?
Consider using a Set screw like this instead.
Although it's small, having that large setscrew sticking off the side is gonna cause imbalance(leading to early bearing failure).
Also, one day, you WILL catch yourself on that screw, and are gonna wish it had been a flush set screw. Go ahead and ask me how I know, I dare you :-)
I was going to use an inset set screw, like you're suggesting, but since I used a 1/4" diameter bolt, there's only 1/16" of threads there, and I'm not sure I have the 1/16" allen wrench in my set, for the set screw that I have, either. I just used what I already had sitting out, that was easy to tighten down on the fly.
You do have a good point about the imbalance potentially damaging the bearings, though. I may have to switch to a normal set-screw soon.
I hope you do an Instructable on making an inexpensive CNC router too!
You know, you're right that there are Dremel clones out there for fairly cheap, but, I had these parts around, too, so, like you, this was a $0 build for me. I think that most people who're interested in building a CNC mill at home probably do have a similar junk pile to salvage through.
Maybe you can exhibit a work maked with it.
