Cheap Easy Dog Run to Build
122,985
41
17
Posted
Introduction: Cheap Easy Dog Run to Build
A couple of times a year we go to my son's property in central Texas. We spend a week or two there; making sure everything is in order and the grass is mowed. We got tired of trying to find a reliable dog sitter so my husband designed this dog run so we could bring our dogs and worry less about them. They like it better because they don't miss us so much.
This type of dog run is much cheaper than $500.00 ones you can buy and they work just as good and they look fairly nice. He purchased the panels about eight years ago at 20 bucks a piece. We already had the wire, gate, and hinges. You will notice a metal fence post that has not been driven into the ground. My husband used it to stabilize the dog run while we connected it together.
The great thing about this run is you can make it more permanent without a lot of labor or cost. We have used the panels for a portable dog run as well as keeping the dogs out of the garden when they can run free in our fenced yard.
I am not a professional and this project has not been tested like companies who make them do; so please use common sense and understand if you make this you are at your own risk. DO NOT USE THIS METHOD AROUND SMALL CHILDREN. THEY COULD TRY CLIMBING THE DOG RUN AND GET HURT.
Step 1: Tools and Supplies
This is what you will need:
Heavy gage wire live stock panels they come 20 foot long 48 inches tall 2x 4 or 4x4 or 6x8 square mesh
How many you need will depend on how large you need to build it. The panels can bend if you bend them carefully.
We purchased ours at a farm supply store in Texas
Aluminum wire My husband likes it because it is easy to bend and work with.
Standard chain link fence gate hinges optional
Old metal gate optional
Metal T fence post optional for a permanent dog run or semi portableabout 5
Sledge Hammer 4 pound
Pliers
Tape measure
9 Safety latches or clamps 2 at each corner and one in the middle
Reciprocating saw if you are adding a gate or need to cut the panels.
Oil using oil on the blade of the saw helps it cut easier.
Step 2: Gather Supplies and Tools
If you are attaching the dog run to a existing fence you would only need 3 panels.
Lay out the panels.
Choose level ground to set the fence up and level if needed making a trench with a shovel.
Step 3: Connect the Panels Together
My husband likes to use the safety latches to attach the panels together because they are quick and easy but wire will work just as good. You may overlap the panels if you want the dog run smaller and don't have a way to cut them down. Just add more wire stays to secure it.
Cut one panel for the gate opening or He has used the safety latches to open and shut the panels when it is portable. If you cut a panel it is best to file the rough edges and slightly round them so they are not so sharp. I liked it much better when he added the gate because it was easier to open and close. It takes more time to set up though and you need to add chain link post, gate, and hinges.
If you want the dog run to be stronger drive metal fence posts as shown in the following pictures at all 4 corners.
Step 4: Attach the Gate If Desired
Here is how we attached the gate:
We drove a metal post in the ground at the front two corners and left a little bit of the bottom part of the post exposed as shown. We placed a chain link fence post over the top of the post and let it set on the bottom section of the metal fence post. Then we connected the hinges for the gate. It took less than an hour to erect after we cut the gate opening.
Step 5: Fence Post
If you want to add strength to the dog run you can use metal t fence post at each corner. It helps to stabilize the dog run. My husband has used it without the post with no problems. The wire can be bent to form a corner. I will share the pictures how to do this although; we did not want to bend our wire and we did not have a scrap to use to bend, but hopefully you can tell from the pictures how it can be done. He laid a piece of plywood on the sidewalk to protect the concrete. Then he laid the wire over the plywood. He placed the white plywood (1/2 to 3/4 inches thick) over the wire so he would have a place to stand and the weight of him standing on the plywood holds the wire firmly while he is bending the wire.
My husband starting at one side of the panel; used the wrench to slightly bend each lateral wire; lengthwise of the panel; bent each lateral about 15 degrees working across the panel. He repeats the process about three times until the corner is formed. I took pictures from panels that we used for a fence. You can see the bend in the wire and how it looks.
Step 6: Sunshiine's Final Thoughts
We have saved a lot of money not using pet sitters over the years because we take the dog run and dogs with us and set the run up when we can. The dogs like it much better than being tied to a tree or post and we think it is much safer. There is plenty of room to put a dog house and add plywood to the top and sides for weather conditions. The price is not too shabby either. My husband was explaining to me you can make a fence without using post by zig zagging the panels.
If you would like to vote for this entry for the Pet contest please come back when the vote button is in the top right corner. Thanks so much for your support.
Thanks for viewing and do have a safe and happy spring!
I like to take the time to thank our sponsors'.
sunshiine
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Pocket-Sized Contest
    16 Comments
    I used the plans onwww.EasyDogHouse.info and built my dog a dog run VERY cheap and easily! It was the best decision I've ever made. To my family and I, it just made economic sense to build a DIY dog run. We spent a fraction of the cost of buying an expensive pre-built one that just have to be assembled anyway...why pay inflated prices for material? The guide on that website is so very easy to follow and it doesn't matter if you're a total beginner like us. We were on a very small budget and found so many wonderful plans for our dog run...it was hard to pick just one, but the one we chose is terrific! We actually built the one that is featured on the website's homepage. Our dog finally has the dog run we've dreamed of and it was VERY affordable!
    How much did it cost you to buy all the supplies to build your dog run?
    Hi Angie,
    Thanks so much for sharing this information with my readers. So happy your dog has a great place to run and play~
    sunshiine~
    What gage is the livestock fence?
    These are very heavy (not flimsy at all). They are called livestock panel heavy gage galvanized welded wire fencing panels.My husband thinks they might be 1/8th or 1/4 inch, but he does not know the gage. I think he is wrong about 1/8th inch because the wire is heavy. He paid about 25 dollars on sale 4 foot by 20 foot long and 4x 4 mesh. He thinks they are about 50 dollars regular price.
    Here is another place to look: http://stockyardsupply.com/index.php/fencing/welde...
    We bought ours here but it does not show the pictures or gage: https://www.mccoys.com/
    I hope this helps, and thanks so much for stopping by to take a peek.
    sunshiine~
    Thank you for stopping by and commenting~ Have a great week~
    sunshiine~
    I would love to know how to bend the corners!!
    I have edited the instructable to show how to bend the wire. I hope this explains it for you. thanks for commenting and have a great day!
    sunshiine
    This is perfect, gives dogs enough space, with them also being safe. Very innovative sunshiine! :D
