Introduction: Cheap Easy Rolling Planer Stand
I just got a bench top planer but I am without a bench. As the planer is very heavy and I don't want to kill myself every time I go to use it I decided to place it on rollers. The easiest and most economical solution I came up with was using a small moving dolly that I got for $6, a piece of 2x4 from a pallet and several bolts. This also made unpacking it very easy for me to do alone.
Step 1: Flip the Planer Upside Down
Step 2: Check the Fit
Step 3:
Measure the base of the planer then cut the 2x4 to length and then lay it out and clamp it.
Step 4:
Once flipped remove clamps and apply bolts and you can use the clamps as breaks. Is this as good as bolting it to a bench and having appropriate height extensions, of course not but a cheap solution for a cheap planer.
MacGyver Challenge
Fix It Contest
