Introduction: Cheap Easy Sew Pants
I love t-shirt reconstruction. This tutorial will show you how to make cute shorts that can be any length for about $2.50, and you do not have to be a master at sewing - I'm sure not.
Step 1: Materials
You will need a shirt, I am using an extra large craft one that I bought for 1.99 at Michael's craft store.
You will also need a sewing machine or needle and thread, I like using a sewing machine though.
Scissors
Pins
And extra material is optional.
Lay your shirt out flat to start.
Step 2: Cutting
To start you want to cut off both the arms and the top.
Note that the amount that you take off the arms will determine how large the seam at the crotch will be. I did not cut enough on this one. You may want to measure.
Then cut the shirt in half down the middle. I folded mine in half to make sure it came out just right.
Step 3: Unfold and Sew
If you unfold the two pieces they should both look like this now. Place them face together (have the outsides facing in) and sew along the 'u' shape.
Step 4: Turn Into Pants
This is the tricky part to understand. If you have experience with sewing, or can think three dimensionally this shouldn't be too difficult. Imagine that these two parts are each a leg. They are what you will be putting your legs through.
Step 5: Sew the Outer Seams
All you have to do now it turn it inside out, and sew the outer seams together. Think about turning already made pants inside out and it will be easier.
Step 6: Add a Waist Band
I like thick waist bands. Because I made the pants too shallow, I will add a waist band to expand the area.
This is just some fabric from an old project.
What I did was fold it over itself. Remember that you can always just hem the edges though, and finish the project without this part.
Step 7: Sewing the Waist Band to the Pants
Here come my horrible sewing skills. What I did was fold the waist band and so the part I want as the top was facing the bottom, and I sewed it to the pants. So, when I folded it back up it it will look clean.
Step 8: Adding the Draw String
Now, you could hem up the pants without the waist band and still do this step to the hem. You could also put elastic in before sewing the waist band down. But, I just so happened to have some extra white fabric laying around.
All I did was cut too little slots in the waist band, then used the safety pin technique to move the draw string to the other side.
Step 9: Rolling
Because of the material you should easily be able to roll it up to whatever length you want.
I think these would make great yoga or sleeping pants, they're super comfortable.
