3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Easy Solar Powered Robot
Make a very cheap, relatively easy to construct robot which will wake up any time you shine a desk lamp on it. There are no sensors on it, although I suppose the solar panel can be called a sensor. I plan on adding solar panels and another motor, and making it controlled by a PIC microcontroller in the future.
http://www.youtube.com/watch?v=BQjmZaHMCZ8
Step 1The Circuit
The Circuit
The circuit for the robot is very simple, it has no digital electronics. It's called a 'miller solar engine' (http://solarbotics.net/library/circuits/se_t1_mse.html) and it allows a small solar panel to power a motor.
The solar panel stores energy over time by charging the capacitor in the circuit.
When enough energy is stored (this is sensed by the '1381' part) the energy is allowed to flow through the motor and the robot moves.
Then the whole process repeats.
In the circuit diagram, C1 is a capacitor, D1 is a diode, R1 is a resistor, and the circled M is the motor.
############--Purchasing--###########
If you buy from www.digikey.com, here are the part numbers for 1381 chips (they 'turn on'/'become active' at different voltage levels):
2v: MN1381-C-ND
2.6v: MN1381-J-ND
3v: MN1381-L-ND
3.4v: MN1381-N-ND
4.2v: MN1381-S-ND
4.6v: MN1381-U-ND
here is the part number for a 2N3904 and 2N3906
2N3904-ND
2N3906FS-ND
I got my solar cell from here:
http://www.flexsolarcells.com/OEM_Components.htm
If you can't find the stuff at those sources try these:
mouser.com
jameco.com
allelectronics.com
or do a google search for BEAM hobby stores.
63 comments
1-40 of 63next »
Aug 30, 2011. 7:39 AMsjoshi3 says:
Hey, U mean by flashing lamp light it works? Okay i am a tyro in this so please bear with me...If u find a way so that u can continuously flash light then the robot will work without stopping ryt? And anyway i can find a way to power a micro-controller with the solar panel??? Thanks a lot!
Dec 28, 2008. 7:48 PMgeeklord says:
Wait a minute, if the 1381 chip goes off at at a certain voltage, wouldn't the thing go off constantly because its connected to the solar panel, or does C1 give it a time delay so that when it gets fully charged the chip aahhh, opens(?) the transistor????
May 1, 2010. 12:09 PMknektek says:
it would'nt go off constantly because the solar cell's current is too low. Anyway the schematic is wrong, there needs to be a diode in series with the cap and cell
Jan 16, 2011. 4:16 AMwobbler says:
The extra diode isn't needed in this circuit. The function of the diode when used in a typical battery charging circuit is to stop the battery discharging through the solar cell when there is not enough light to power the solar cell. Because this solar powered circuit only works when the sun is on the cell, the diode is superfluous. It would also, in this case, lose some of the voltage generated by the solar cell in the diode drop voltage and therefore make it more inefficient.
Jan 16, 2011. 5:41 AMknektek says:
But, the charging current will disharge through the solar cell and cause inneficency. But the diode is not manditory
Jan 16, 2011. 2:54 PMwobbler says:
This circuit is designed to work only when the solar cell is actually in light, so the cell is always "powered up" and therefore effectively at a greater voltage than the capacitor, so there is no charging current to discharge through the solar cell as such. This circuit does not demand that the capacitor retains its charge when the solar cell isn't in light and so the diode isn't needed and there is no inefficiency without it in this case. However, if you were using a battery or supercap which you wanted to retain its charge when the solar cell was in the dark, it would be necessary.
Jan 18, 2011. 11:03 AMknektek says:
Exactly {O{_{O{
Feb 28, 2010. 3:50 PMthestyrofoampeanut says:
 theres so many different types of diodes which one did you use?
May 1, 2010. 12:07 PMknektek says:
...Just use a high speed skotchy (spelling plz) diode. I would reccomend getting 3 in parralel so that there is almost no current loss.
Jan 16, 2011. 3:09 PMwobbler says:
the MN1381 takes only microamps, so there is no need to use more than one Schottky diode, the others will just be wasted. The advantage of using a Schottky diode is that it has a lower forwards voltage drop over other diodes (0.15–0.45 volts versus 0.6–1.7 volts for a normal silicon diode) and hence less voltage is lost in the circuit where it is present. However, this diode only serves to raise the voltage at which the MN1381 triggers relative to your circuit ground, so using a normal silicon diode just means getting a different MN1381, rated approx.0.5- 1v less than the one you might have used with the Schottky.
ref: http://en.wikipedia.org/wiki/Schottky_diode
Aug 16, 2009. 12:08 AMpaintsniper says:
can u pls show me a top view or email me better pics to make it easier to build without using the schematic
Jan 28, 2010. 1:23 AMthestyrofoampeanut says:
 agreed im not gettin much out of this picture
Oct 26, 2010. 10:54 AMsparkspooky says:
thats one big solar panel....=D
Jan 9, 2010. 4:59 PMsalahaddam says:
www.middlecreekmerchants.etsy.com
They have some Solar Robots and Kits for sale!
Jan 2, 2009. 7:48 PMgeeklord says:
I was gonna try using a 555 timer for this.
Apr 29, 2008. 7:42 AMmatejasj says:
So we are trying to build the robot and are wondering what motor was used, we are struggling to find one that has a low enough current. Thanks!!
Jul 12, 2008. 2:41 PMUnit042 says:
Aug 10, 2008. 6:04 PMnathanzhang says:
no actually you linked to a different website. Solarbotics' website is http://solarbotics.com. We're dealing with an ecommerce storefront hawking robotics equipment, not OSS here...
Aug 10, 2008. 8:28 PMUnit042 says:
I'm not sure what OSS is, but I only meant to provide an additional robot help website. I did not mean to correct your posted URL.
Aug 11, 2008. 12:50 PMnathanzhang says:
OSS = Open Source Software
in case you didn't know.
From first glance that website looked like an OSS website, but now I'm starting to harbor doubts...
Dec 28, 2008. 7:39 PMgeeklord says:
Wasn't it also the current CIA, formed in world war two? Operation of Secret Services or somthin...
Aug 11, 2008. 4:58 PMUnit042 says:
Thanks for clearing it up. Wkipedia says that OSS is some country somewhere, while google said... well... a that I got a couple hundred thousand hits on all different types of stuff that bear no resemblance to the context of your post. As to the site, well, if you click around, it's actually where some robot guys who run solarbotics.com archived a bunch of solar-powered robot schematics. (Feel free to look at the website for longer than 10 seconds) In fact, it's probably where the schematic for the solar powered robot 'ible came from.
Sep 18, 2008. 4:24 PMgeeklord says:
Ok ,this is starting to get annoying.......... In plain English what does a transistor do, beyond "amplifying and switching"?
Sep 18, 2008. 6:11 PMXellers says:
Before I knew what those magical things did, I was just as annoyed as you are now....
Here's how to work one:
By running electricity from the base to the emitter, you allow an electrical current to flow from the collector to the emitter. This is useful because you can amplify a signal, or use the device somewhat like a relay to build logic gates and other interesting things.
NPN and PNP symbols with base, collector, and emitter labeled:
http://www.sunybroome.edu/~grace_t/micro/lab/npn_pnp.gif
Ignore the pinouts of the transistors at the bottom of the page. Notice tthat the arrow's direction indicates whether the transistor is NPN or PNP type.
Hope this helps! :-)
The differences between NPN type transistors and PNP type ones lies in thier composition and therefore their behavior. an NPN type transistor will act like the transistor described above, and a PNP type transistor will act in the opposite manner. The gate is normally on, and it is turned off when a base - embitter current is applied.
Dec 28, 2008. 7:25 PMgeeklord says:
yep, got that now
Dec 28, 2008. 3:21 PMiknowirule3 says:
I'm not very old and I can't understand Techno-Talk, so I don't even know what to buy. From, Me
Aug 11, 2008. 10:57 AMRadioactive_Legos says:
I want to make a 3V coin cell-powered robot like this. Would it be possible to use the coin cell, a capacitor, an NPN transistor and a motor to accomplish this (Cell charges capacitor, and when capacitor reaches voltage high enough through the base to trigger transistor, current from capacitor is let through to motor)? Thanks
Jul 10, 2008. 4:42 AMyourtubemeera says:
hello
does anybody has the circuit diagram of this robot
http://www.robotroom.com/Sandwich.html
i really wanna make this
n don hav money to buy d book or the PCB
Jun 23, 2008. 2:59 PMnathan18 says:
i just signed up and i need some help to get started
Nov 9, 2007. 11:28 AMcrazycade77 says:
He yhow did you get the battery out of the CD player?
May 28, 2008. 5:48 PMchemy999 says:
HELP my Walkman is undisectable HELP
May 29, 2008. 4:17 PMchemy999 says:
i have unscrewed all the screws that I have found it still is keeping together p.s. i don't want to smash it
Nov 10, 2007. 7:52 PMcrazycade77 says:
Do you need the worm gear and is there a chance people could buy a motor from somewhere?
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
