3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Herbal Vaporizer
This is an alternative to the very expensive variable temperature vaporizers. It allows you to use different types of herbs such as tobacco, spearmint, and eucalyptus that vaporize at different temperatures without burning them. The entire project will cost between $20 - $40, which is a small fraction of the price of vaporizers you can buy on the internet. This can be used to vaporize marijuana, but i do not promote it unless it is legal where you are.
Step 1Materials
Materials
You will need...
A soldering iron (preferably one with screw in tips)
An empty quart paint can (or any container that is mostly airtight, and will not react to heat)
A 1/2 inch copper pipe cap
A screw that matches the threads on the end of the soldering iron, no longer than a 1/2 or 1/4 inch. ( Or a nail that fits in the end of the soldering iron and can be tightened snugly and has a fairly wide head)
A small amount of plumbers epoxy putty
A dimmer switch with the highest wattage rating you can find.
A small diameter tube that wont react to heat, and won't release chemicals.
A digital thermometer with a fast response time. (I use a fluke multimeter with a thermocouple, but i don't expect everyone to have one of those.)
Tools:
A  drill with a bit just larger than the nail or screw you will use to go into the tip on the iron.
A nail or other sharp object that can penetrate the metal can.
A pair of pliers
A knife or wire strippers
A small amount of tape
5 comments
Aug 15, 2010. 2:25 PMgarrettanderson983 says:
Uh.. Why would anybody want to vaporize spearmint or eucalyptis?!? What would be the point? Btw tobacco is dangerous and it's far more addictive than heroin... Use Cannabis :-)
Jul 26, 2010. 1:11 AMfluidpaddler says:
smoking through copper is not good for you
Jul 13, 2010. 2:10 PMlemonie says:
Interesting, have you thought of dismantling the soldering-iron and maybe just using the main body instead of the copper-tip?
L
Jul 14, 2010. 2:24 PMlemonie says:
I meant just the hot bit of the iron (that I've burned my fingers on a few times)
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:goboom
