Cheap (If Not Free) Mini Exhaust Fan - Great for Solder Fumes
6,661
12
4
Posted in WorkshopTools
Introduction: Cheap (If Not Free) Mini Exhaust Fan - Great for Solder Fumes
Have you ever been soldering and thought, "These fumes can't be that great for me."  Me too.  Never one to take up extra outlets, I decided to throw a super cheap little fan together.  I'm sure you can make 1,000 different variations of this thing, so be creative and have fun!
P.S. This is my first instructable, so please pardon the garbled text and blurry images.
Step 1: Parts Needed (Or at Least the One's I Used)
This is a very simple project, and being so man different parts can be used.
Here's a list of what I used:
1. Fan out of dead power supply (120mm I believe)
2. 6v Lantern Battery
3. Soldering Iron and Solder
4. Hot Glue and Gun
5. Diagonal Cutting Pliers
6. Toggle(On/Off) switch from lantern that the 6v battery came from.
7.  Wire Strippers
Step 2: Taking Fan Apart...Or Not.
This part is optional, but I think it makes the final product look a little more swanky.
1.  Flip fan over and snip the little bars holding the actual motor and blades in place (2nd Pic).  There should be around 4 little plastic bars to snip.
2.  The fan should look like this when you're done snipping (picture 3)
Step 3: Installing the Switch...Or Not
You don't really need a switch for this project, but it will make it look much cleaner.  I suppose you could just use an alligator clip on a terminal if you don't have a switch handy.
1.  There's probably a little pin connector on the end of your fan leads, so just go ahead and snip that off.
2.  Strip the end of the wires.
3.  Pick a line to snip. I chose the positive lead.  Strip ends off original lead, and the piece you snipped off in the last step.
4.  Choose a switch and line it up.
5.  Solder that bad boy.
Step 4: Glue It All Up Baby!
All that's left is to solder your leads to the battery and glue it all up!
1.  Take ends of leads from fan and stick them to the terminals to see if there's any juice from your battery and test your switch.
2.  Wrap leads around spring terminals and put a little dab of solder on them for maximum awesomeness.
3.  Take back of fan motor and hot glue that sucker on the side of your battery, making sure that the wires are coming off the side of the battery.
4.  Glue your switch in place.  (I chose the top of the battery.
5.  Glue your wires down and away from the fan blades.
6.  Place near soldering station to prevent cancer and other horrible diseases!  haha
YOU'RE DONE!
Wasn't that easy!?  (And probably painstakingly over-descriptive)  It's my first instrucatable...so what do you expect?   =)
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    4 Comments
    can we use another batteries for this? I mean, like 9v.. is it have specific effect?
    Looks good, but the fumes stay in the room... L
    Haha, well maybe I'll rename this...Placebo Fan. I'm sure the amount you actually inhale is significantly reduced.
    Yea, if you don't want it in your eyes or up your nose. Be useful for cooling things down too.
    L
