Cheap Light Box for drawing or inking or...
A light box is a box with a light in it. Pretty simple stuff. I just can't bring myself to pay $50 (on the low end) for one. This one was put together in about 15 minutes and cost less than $15. Lights of America makes a 13" florescent lamp that I bought at Wal*mart for about $8. The box is a Sterilite storage box with a frosted bottom and cost about $4. I like making stuff, but I like drawing more so this is as simple as it gets.
Step 1Position florescent lamp
Up to 8 of the under-cabinet florescent lamps can be daisy-chained together with a pass through cable that comes included. To keep it cheap, I opted to use a single lamp. Position the unit in the center of the underside of the lid. I super-glued the light fixture to the lid, but you could use tape. Make sure you cut a small notch in the lid to allow the power cord to pass through without interfering with the lid closing.
31 comments
Jul 8, 2011. 12:39 AMbeastenick says:
its ridiculous how expensive light boxes are, considering the cost of their components...i built my own 18x24 out of wood and glass, but it took time, patience, and tools...yours is by far the most simple and elegant solution to the diy lightbox problem ive seen. great job, thanks for sharing
Jun 27, 2010. 5:34 PMAngelBunny says:
Thank you for this instructable! I just finished assembling mine, it took just 10 minutes!! My step-daughter and I have wanted one for home for ages, this is just awesome and perfect!
Jun 20, 2010. 9:36 AMkellimaier says:
My daughter has been asking for a light box...thank you so much!
Mar 17, 2010. 6:12 AMkristenpowersink says:
wow awesome...haha I know you posted this like two years ago but it's still GREAT today! I have a broken light box so I am just gonna take out the guts and put in one of these florescent lights...it's genius!
Oct 27, 2009. 1:23 PMsee-saw says:
Thanks for posting this - brilliantly simple and just what I need.
Up until now I've been using my monitor as a substitute which has worked pretty well.
Aug 14, 2009. 9:25 AMkc1313 says:
oh thank the lord!!!! i, too, just can't bring myself to pay that much for a light box and i thought i was clever but hot dang my problems are solved!!!! thanks so much! as an aspiring tattoo artist, my job is tracing!
Jul 13, 2009. 6:02 PMmismonster says:
OK I am so doing this like...tomorrow (plexi store is closed already). Thanks!!
May 31, 2009. 10:22 AMjekief01 says:
How about lining the Sterilite storage box with aluminum foil to keep that light focused up towards the top (area you want lighted)? I'm curious if that would help so that you wouldn't need another light.
May 25, 2009. 3:33 PMchelle1958 says:
Fantastic! I have been the crafts supply store several times debating whether to put out the $50 bucks for their lightbox and online even higher. I'm a DIY and it just seemed like it could be made. Whala......you are proof of it's existence. This is cool stuff. I am a cake decorator and I work with rice paper and needed a simpler way to transfer designs. Thanks for sharing the knowledge. If you ever need a cake, look me up!
May 1, 2009. 3:52 PMPonchoLibre says:
I love this idea it is awsome and I will make one! I just have one question does the heat from the light warp the plastic container at all or does it get really really hot after using it? so hot that it may be a fire hazard?
Mar 11, 2009. 6:20 PMTwilley says:
Did you have any issues with the plastic container warping or bending at all? Not necessarily from heat, but from the pressure of working on top of it? Also, is the fluorescent light powerful enough to work through Bristol board?
Oct 28, 2008. 7:38 PMlostdixie says:
I think this was a very creative idea! If I decide I need something larger than what i purchased, I will definitely go this route! Ummm, I found a "spiderman" children's craft lightbox, LOL, for about $13, with shipping, around $18. Heck, I don't care if it's for a kid, if it works, it works!!! It's large enough to accomodate a standard size of paper. Cheap and no labor, hehe, works for me too.
Sep 5, 2008. 3:56 PMjoeysdreamgarden says:
thank you again, I made a lunchbox lightbox! For £3.75 which was just for the lamp (which could be brighter but was fine for what I wanted - tracing through paper and calico, painting on the calico - very good results!). The lunchbox had a bit of raised text which I smoothed out with the back of a spoon heated over a gas ring on the cooker, which worked fine. For people in the UK, I have seen very useful plastic boxes, available in a range of sizes, completely smooth on both sides and neatly slide together. They are sold at Hobbycraft stores. You can likely get these in the US, a lot of stuff at Hobbycraft is imported from the US.
Jul 27, 2008. 10:06 AMjoeysdreamgarden says:
Fantastic! I did wonder about using a string of cheap LED fairy lights, for their low power consumption and little heat generated but after seeing your idea, this may be the way to go... though I could experiment with LEDs first. I had been looking at lightboxes, and they're so expensive! So this is a fab idea & instructable. :D
Jun 28, 2008. 10:14 PMshooby says:
The material that these plastic containers are made out of tends not to let enough light through, and is also pretty flexible and soft. I'd recommend buying a pre-cut piece of plexi glass, and use that for the drawing surface, after cutting a section out of the top of the box. The underside of the plexi can be sanded until it's frosted, too get equal light distribution. Yeah, this doubles the cost of the project, but it'd still only be about $20 ($10 for the plexi).
Jul 1, 2008. 7:46 PMshooby says:
If you were to do so, I'd recommend building a box from scratch using acrylic entirely. Assuming you can get it cut (art stores are best, they use plexi for framing images), you can join it really easily using acrylic solvent, which is either di or bi methyl acrylate. Fun to work with, and easy to get nice looking results.
May 23, 2008. 11:27 PMMr. Rig It says:
This is a really good example of ingenuity at work.
May 22, 2008. 12:56 PMLaceyD says:
Thank you! Wow, simplest really is best. I can buy that light and have a light box today!
May 20, 2008. 7:48 AMcasey321b says:
Ive been wanting to make one but use the money for other projects. Now I see that I can make this cheap bad boy. +1
May 22, 2008. 10:29 AMcasey321b says:
thanks I'll use 2 lamps
May 20, 2008. 5:33 PMdchall8 says:
Thank you for a practical solution that seems to elude people. I use a Sterilite box to diffuse the light when I take pictures of necklaces or any other small objects.
May 14, 2008. 6:31 PMtruovrld says:
This is great... I've looked at light boxes, but never thought of making one. I may even have the materials laying around! Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:UID
