Introduction: Cheap Machining Coolant Sprayer
Picture of Cheap Machining Coolant Sprayer
This is my cheap and efficient coolant system which runs off a compressor.  Basically its a cheap airbrush but with a pvc hose filling the unit with coolant (I use WD40).  The price of these coolant sprayers starts at about $100 for the most basic and quickly go upwards of $200.  I thought an airbrush would do a better job as it is far more variable, plus if any parts break then they are very cheap to replace.
Basic Items
-Airbrush $10
-PVC Hose 6mm ID  $2
-Zip Ties
-Neodimium magnets $8
Items to automate operation
- Air Regulator $16
- Solenoid Valve  $30
Setup
Fairly easy, just add oil instead of paint and epoxy the neodimium magnets to the airbrush, the other magnet fits next to where you need the airbrush securing.  This allows me to place the coolant exactly where I want it quickly.
Im sure you will wish to setup your coolant system to suit your equipment.
Automation
I got board of switching the unit on and off so I glued the airbrushes trigger down and fitted a solenoid valve which ran off the motors power.  Now when I turn the lathe on or off the coolant starts & stops automatically, just like pro cnc machines.
Hope you like it :)
Thehappygecko (author)2015-06-13
I like this set up. I think I will make this and add an opposable sprayer head. 700 × 700 - tormach.com and make 2 or 3 of these (Lathe, Mill, Bandsaw) I like the addition of the Solenoid. I think I will just add a rocker switch onto the switches that are already there instead.
About This Instructable
1,949views
15favorites
License:
More by ant...:Cheap Machining Coolant Sprayerwacom pen - learn to find it!
Add instructable to:
