3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Man's Cigarette Smoke Filter
Cheap Man\
As of late, my smoking habits have increased and I've used my computer fan to pull the smoke away from me. I hate having the smoke that I don't inhale in my face, it burns my eyes. I understand the dangers of smoking, but then again, I don't want my computer filled with the smoke or anything tobacco produces. As I've been told after asking a question in the answers section of Instructables, build an air filter. As some searching and browsing through others Instructables on air filtration and purification I realized I have a strict budget of $0.00USD. So I needed something cheap, home-made and what would keep the smoke relatively filtered, or at least pulled away from my computer, and me.
Step 1Materials/Parts
Materials/Parts
I didn't want to spend an money. So, I used parts from around the house and old computers in the basement to build my filtration system.
First off, a FAN to pull in the smoke is highly recommended. I used an old CPU fan and it's mounting screws.
Second, I used a small CPU packaging box for the support.
Third, some sort of filter. I used a thin piece of a napkin.
Fourth, a power supply. I used a 9V battery and its corresponding(matching) plug.
Fifth, something to hold it all in place. I chose electrical tape, since it was all I had around at the time.
You will also need tools:
Wire cutter/stripper(not pictured)
Knife(not pictured)
Screwdriver(not pictured)
5 comments
Mar 23, 2011. 3:30 PMslianin9 says:
I would recommend using a dryer sheet as your filter media. They help to trap smoke and freshen the air at the same time!
Jul 4, 2009. 2:41 PMharrison94 says:
Good idea but what happens to the smoke in the box after cause i dont think it holds much. Also, you could do it with a normal fan pionting away from you
Oct 25, 2010. 12:34 AMguitarist996 says:
the smpke is pulled in through the hole the fan is sucking it into, and then theres a hole somewhere else where it comes out, covered by the filter (napkin in this case) :)
May 9, 2009. 6:10 AMlemonie says:
That is pretty much exactly what I was thinking of - good build! L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:foxy1paco
I've been around since early 2008, mostly lurking and trying out random Instructables from time to time. I've made a few attempts at making some instructables, but I rush through the actual production...
more »
