3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Miniature Ball mill
Hi, in this instructable, I am gonna show you how to make a miniature Ball mill, that you can use to grind chemicals and stuff. First, this is my first instructable, so any constructive comment will be apreciated. Second, I am not responsible for what you do with the chemicals you grind.
Ok, so lets get started!
Step 1The materials
The materials
We wont need a whole lot of thing. Just these few thing:
-Film canister
-Grinding media. (Lead pellet)
Also, if you want a more efficient mini-ball mill, you will need:
-Epoxy paste
-A metal bit (Usally from a drill or something like that.
Tool: A drill
20 comments
Jan 24, 2012. 7:35 AMbatman96 says:
what about marbles in a bigger drum? u can get 100 @ the dollar store.
Aug 1, 2011. 12:21 PMLildevil963 says:
yeah um dont do this with a dremel and then put it on the highest setting the thing went flying off the dremel and the epoxy held but the cap of the container litterally was ripped apart
Sep 7, 2011. 11:12 PMlpdunwell says:
you want to set a ball mill to spin at a low enough speed, so that the media doesn't just stick to the sides from the centrifugal forces. in such a tiny mill this is going to be far less than a dremel on max power (that would be like 20k-30k rpm), duh
Jan 27, 2010. 11:12 AMpancotti says:
is coppper a safe media? is there a certain amount of media to use in relation to the mass of what im grinding?
Dec 29, 2009. 11:55 PMstephenniall says:
i use this in my dremel multi to make a little bit of charcoal powder
Apr 25, 2009. 1:02 PMlemonie says:
Ball mills work better with balls, and lead is a bit soft for grinding. Can you get hold of some steel BBs? L
Apr 27, 2009. 6:11 AMPKM says:
It depends what you want to grind- lead is soft but it's stil harder than charcoal or _NO3. I thought steel was frowned upon because you want something non-sparking if you are grinding pyro compositions. Yes, for rock polishing you might want something harder but for that use I'd expect the name "rock tumbler"- to me "ball mill" says pyro.
May 7, 2009. 4:25 PMramses says:
sparking doesn't matter unless you are milling compositions (blackpowder) I would recommend different balls for different chems; steel for sulfur/sulfides/sulfates, oxidizers, fuels, maybe a dedicated set for metal powders and lead/brass/bronze/bismuth/something else for BP.
Oct 17, 2009. 4:56 PMScar16 says:
 blackpowder & gun powder
Sep 23, 2009. 12:09 AMsharlston says:
how long would i have to run it to grind aluminium
Oct 4, 2009. 5:55 PMramses says:
I've heard 72hrs minimum, in a larger drum with at least half inch steel media
Oct 5, 2009. 2:05 AMsharlston says:
not bad my ball mill can make pint of charcoal powder in 30 mins
Oct 6, 2009. 5:30 PMramses says:
I remember you are supposed to add a few wt. % of some chemical used in candle making to the mix to coat the powder. Apparently, it greatly increased milling efficiency, too.
Apr 27, 2009. 10:43 AMlemonie says:
Well it does depend, I guess I was thinking of coal, limestone etc... (Insustrial)
L
Jul 30, 2009. 2:10 PMsharlston says:
i would suggest ball bearings or metall bb's for grinding media
Jul 30, 2009. 4:23 AMsharlston says:
what would the hardest thing that this thing would grind be?
Apr 24, 2009. 7:30 PMjtobako says:
Nested comment boxes on pics don't work-only the outside one activates text. How slow do you have to go to get the 'advanced' one to work? I mean so that it actually grinds something?
May 7, 2009. 4:29 PMramses says:
you might be able to use one of those Knex motors, running off a wall wart. you could gear it if you have the "gear" pieces, and make a stand out of knex. replace the shaft with a short knex piece.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:powextreme
