Cheap Pet's Leash
2,473
12
6
Published
Introduction: Cheap Pet's Leash
This is my first Instructable!
All people that have big pets know how easily the leashes break  or wear out.
Replacing a pet's leash can sometimes be hard work to find exactly what you are looking for an for that matter also expensive.
This Instructable will help you to do your pet's own chip leash.
Step 1: Needed Materials and Tools
You will need:
- A nice rope that withstand some heat (a good quality one is enough)
- Some metal wire (about 30 centimeters)
- One strong metal clip
- A wire cutter
- A pliers
- Some tape
- A hot air gun
- Some pieces of 25mm diameter shrinking tube
- A vice if possible
Step 2: Calculating the Leash Hand's Lace
Take the rope around your hand and take the end of the rope to the tip of your index finger. This step determines how much rope you need to have for your hand and harm size.
Step 3: Making the Hands's Lace
Cut about 15 centimeters of wire and wrap it around the rope's hand lace.
Make at least three turns on the wire using the pliers. You can also press the wire afterwards with a vice so it would be tighter and stronger.
(The wire thickness depends on the thickness of the rope and pet size but is better to use thicker wire for safety reasons)
Step 4: Covering the Hand'd Lace
take a couple of pieces of tape (about 5x2,5cm) and cover the V lace shape to the wire. this tape is optional and is needed for better finishing of the rope's lace.
Step 5: Clip Attachment
Insert one shrinking tube on the rope and pass the rope though the clip's loop.
Note: You may skip this if you choose not to do the finishing with shrinking tube.
Step 6: Finishing
Move the shrinking tubes over the wire turns and use the hot air gun to hot shrink the tubes.
Attention! Take care of the rope's type because of temperature. There are some types of rope that are plastic base and cannot have to much temperature!
Note: If you want you can tho the leash finishing using just good quality tape over the wires.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    6 Comments
    I like the heat shrink tubing!
    how is it on the dog pulling on it? does it come undone easily?
    Hi deadsystem , it does undone easily because it uses a metal clip holder? only needs one finger to get undone.
    my dog is a puller so that would be bad but it is a good looking design. maybe i can modify it so he cant escape me. lol
    Wouldn't it be cheaper just to buy one? Good instructable though.
    Maybe it would but if we want to have a longer leash or custom one I guess this the way to do it :)
