3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap Photography Studio Backdrop Mount
Step 3Case the joint
First and foremost, find an appropriate spot for your backdrop. Against a wall is good, whereas middle of the room (or anywhere there is a draft) is probably not so good.
Once you've found your spot, locate a ceiling beam near one of the outside ends of your area. You can tap a hammer gently on the ceiling, drive a small test-nail, or use an electronic studfinder to locate the nearest ceiling beam.
Measure 6" from the wall and mark the beam with a pencil. From that point, make a second mark 112" over (still 6" from the wall)and test that spot to verify that it will also be driving into a beam (ceiling beams are generally 16" apart...what you want to mark is a beam that is just over 9' away from the other mark, so 7 beams over will be 112").
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:reedzilla
