Cheap Rapid Cord Attachment ( Knotless Gear Tie )
1,816
77
4
Published
Introduction: Cheap Rapid Cord Attachment ( Knotless Gear Tie )
I had been inspired by some existing products like fishbone, piranha and especially loop alien and tried to figure out how they work.
Especially loop alien is essentially a ring with something protruding on the outer surface. So I realized that the same tasks(or at least some of them) could be performed by something much cheaper and easy to find.
The first idea of a suitable ring with something protruding was a bunch of spare (ikea) curtains rings.
Step 1: Sliding Bond
This is the sliding bond used to tension cables for tends, tarps etc.
Step 2: Non Sliding Bond
pull a pinch through the hole
then twist the pinch
put the twisted pinch over the protrusion
Step 3: Non Sliding Bond - End of Line - Little Ring
Step 4: Hang a Loop (ring on the Line)
This is useful to hang a loop(like a lanyard of a knife, torch, camera, compass,etc) or a noose at the end of another cord at the end of a line in a way very easy to detach. I't useful to hang things and to lift things when you have a large number of loads to lift.
In this case the ring is not attached to the loop of the object.
Step 5: Hang a Loop (ring on the Loop)
This is useful to hang a loop(like a lanyard of a knife, torch, camera, compass,etc) or a noose in the middle of another line(for example a clothes line) in a way very easy to detach. In this case the ring is attached to the loop of the object.
This is useful also to connect 2 different lines ending in 2 nooses
the video shows how to connect and disconnect respectively.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    4 Discussions
    Awesome idea! Where did you get the rings from? I Googled "Ikea shower curtain rings" but couldn't find a match, did you use anything I can find at Home Depot?
    KirsDe
    3 years ago
    brilliant! love this!
