Perhaps you've seen one or two in your hometown, or not at all. Recumbent bikes tend to have a (lets say) "mature" following as compared to it's traditional bike counterpart. Perhaps that's because 'bents are more expensive due to their comparatively low production volume. For this reason, you'll find a lot of people making home built 'bent frames and fairings.
For this project, I'm making a short wheelbase (SWB) 'bent on a very small budget and recycling components from other bikes in addition to a frame. I call it
The WidowMaker
I should mention, WoodenBikes.com is an awesome site worth checking out ;) If it wasn't for encouraging words from the site (and meeting/talking with the man behind the site at Maker Faire) - I would have been weary about mounting a crank in wood :p
One day, I want to build an awesome 4x4 tandem battering ram :D
Remove these ads by
Signing UpStep 1Materials and Tools Used
1 Womens Beach Cruiser frame with rear wheel and coaster brake
Some pine 2x4
5 Bolts/nuts
18 washers
1 rear derailleur
Scrap .5" PVC and cement
Extra chain
20" wheel from a children's bike (optional)
1 piece crank from another donor bike (which also gave up chain and derailleur)
Tools
2 C Clamps
Adjustable Wrench
Saw
Drill and bits
Hole Saw
Chain Tool
Screwdriver
Hammer (for removing BB cups)
Measuring tape (for measuring X-seam etc.)
Something straight and long (measuring tape works)
Optional
Crank puller (or go to your local bike shop and have them pull your crank - for the non 1 piece crank guys)
There won't be any hack sawing, welding or irreversible changes made to the frame to be converted ;)
thank you.
If you've ridden a recumbent before, you either love it or hate it. Most people that are not already set into their hard core biking ways absolutely love it. There's something called the 'bent smile - because that's the only thing 'bent owners can do :p
There are hundreds of different recumbent positions and configurations - compared to the two triangle bike design that has been optimized for a VERY VERY long time... But the general benefits are:
More comfortable
Better for your back (with a proper seat)
You can be in a more aerodynamic position
Pedal force isn't limited to arm strength and body weight - you're basically doing a leg press into the seat as opposed to holding yourself down by the handlebars.
A draw back for two wheelers is hill climbing ability -- you can't stand up use gravity to put more power down. So on a hill, go too slow and you'll fall over. A trike solves that, but will very likely be heavier.
Not to mention every single speed and distance/time record was completed by a recumbent -- 81mph on a bike is nothing to ridicule :)
The biggest drawback is cost as they are not mass produced... bugger.
Fairings, yes - Lead vehicle to reduce air resistance - no - this is not allowed by IHPVA (the organizing association that runs the speed events) rules. They even have rules about the minimum trailing distance (I believe it is something like 200m) as a car behind a vehicle can provide an advantage.
But mind you, fairings aren't some exotic recumbent only feature - any bike can be faired ;)
Relatively poor visibility, in both the "seeing things"
I completely disagree. I naturally want to face forward and upwards rather than somewhat downwards towards the ground (this is comparing a road bike to a road recumbent two wheeler). One of the reasons a lot of people enjoy bent's is for this very reason - it's much easier to enjoy the world around you :)
"being seen" senses of the word,
People say this all the time... I disagree from an expirience point of view.
First, cars tend to swerve out of the way to miss turtles and other small debris. I've never seen a recumbent smaller than a turtle crossing a road. At the same time, cars claim to have never seen other cars when they get into a crash. You can't expect anyone driving a car to see anything regardless of what bike you're on.
From the aforementioned experience point of view... I'm currently living in San Francisco and ride my recumbent everywhere. I command much more attention while on my 'bent than when I'm using a loaner diamond frame. Cars get a lot closer to me when I'm on a diamond frame and they keep away when I'm on my 'bent. It's nice :D
In Orlando, FL - I ride on the road. Orlando is NOT a bike friendly city like San Francisco.... I had been riding on the road with the frame pictured below more than 6 months without issue on roads with a speed limit of 45 ;) I do try to avoid bike lanes, where possible, as they're poorly designed - road debris gets pushed in by cars. Normally, these small items are fine for cars, but potentially detrimental to bikes :/
Yes, I will admit that there is potential risk while riding in the door zone. Lucky for me, all of the accidents I've heard of are of people getting "doored" while riding a diamond frame bike... So no one can claim visibility in that respect - if the person doesn't look, it doesn't matter how big, tall, bright or otherwise you are ;) The point is, be predictable - I'm not saying don't take safety precautions - I'm saying the best safety precaution is how you ride, not what your ride or what you ride with.
Recumbents have a considerably lower profile
There's a different tool for every job. Your comment is not well informed ;) I ride a high racer recumbent - which is, in fact, a high profile 'bent. High racers, according to the manufacturers, have been popular due to their dimensions and wheel sets... But again, what good is this profile when the profile of a car is too small to prevent an accident?
Riding a bike for utilitarian reasons---as opposed to weekend recreational riding---demands somewhat different tests of practicality.
I totally agree - by the same token, understand that "recumbent" does not refer to a bike with similar geometry such as a diamond frame bike. A tri-bike has an overall similar geometry to a commuter. But both of those bikes have very different handling characteristics as they're different tools for different jobs. I don't ride a super low bike meant for racing.
The lesser ability to deliver gravity-assisted pedaling power can also impact the hauling of heavy loads
I again, disagree. If the recumbent bike has the same drive train as the non recumbent - I'm totally with you. But this isn't the case. Designers know that gravity isn't going to help - so we're geared as such. The breadth in gearing on my 'bent is huge enough that I've got an instructable on how to move house by bike - and I used my 'bent, fully loaded in San Francisco - a city not known for it's level terrain :)
As a side note - my intentions aren't argumentative. You've provided clear, thought out points that I semi-frequently hear at traffic lights while talking with other cyclists. Most of these fellow riders have never ridden a 'bent or have only tried and say it's "hard" :D I've been on 'bents for >4 years, in traffic an everything, and have no plans to stop :D I'll try to get helmet cam footage while riding in traffic for a space comparison :)
So I guess I should show a picture of my bike :D It's dual ETRO 559 wheels - so 26" equipment fits on it :) This isn't some obscure bike that isn't representative of 'bents - because no frame is representative of the recumbent community. This frame was commercially manufactured and a new version with similar specs is still sold today :)
Yes, I love my bike - it fits on bus bike mounts, I can bring it on the subway and while cruising downhill, I can put my feet up lazy boy style :)
Curbs are also a good point - I make it my business not to jump curves on my normal bikes anyway :p But going up curves could be a problem - although, I was never able to get that stupid beach cruiser up any appreciable curb (I wouldn't expect it to either). I can see where that would be a benefit for some though :)
Pulling a wheelie -- yes, that too. The only time I pull up on my bike is for comfort reasons (unavoidable bumps), which isn't a problem on a 'bent with a proper seat :p But I ride almost exclusively on paved roads (and don't go up curbs anyway).
Off Road riding.... Well, there's plenty of video out there of people taking their purpose built 'bents off road :p
But the emphasis must be put on purpose built - I mean, I wouldn't expect my road bike (or even that beach cruiser) to perform very well off road :p In fact, I know explicitly that they don't perform well at all :p
So, revised drawbacks
*hill climbing ability for heavier 'bents
*no wheelies (or very hard to)
*going up curbs may be a problem
*potential public transportation issues (that could be a big issue for some)
+/- for off roading - I haven't done it myself (and don't do it normally), but it seems people do it without issue. I'll rank this with "balancing is harder" - it's not harder, just different :D
Oh no! I didn't mean to imply that ;) One the guys I ride with does - but we call him the "new guy" because of the goofy stuff he does (and shouldn't do). The main reason I don't is because I'm riding on an old old steel lugged road bike, and really can't afford to damage my wheels. Really, I built a 'bent using dumpster materials :p
Twice, for example, I've been hit by ignorant and careless bike riders that did not announce that they were overtaking me
Yeah, I've been there too (just not on a trail) - it bothers me more when they're going the wrong way (I usually will yell something at them in cases like this).
In any case, my apologies if anything came off offensive to you - not my intent :)
Sorry about the bad video link
81mph on a bike?!?!? Taht iz fazt!
The nice thing about using these cheap 1 piece cranks is that they hold themselves together with compression. The only adjustment is 1 threaded nut. The cups themselves are snuggly fit in the wood and I haven't seen them try to work their way out as of yet :p
As he said, keep low expectations and you'll get amazing results :D
I was just thinking of how to use the entire BB shell... If I were to do it that way (try again)... I would drill a semi circle into the top of the boom and place the shell inside. Then use U-bolts or something similar to hold it down. Even some good water proof epoxy (in case of rain). Just an idea :D
I modified the final step to make to more clear :) The numbered items are issues and tips to avoid problems later ;) Key problems: seat (my lack of a bottom seat), I need suitable handlebars, and a noisy idler ;)
That handlebar looks like it might work under the frame too. IMO that high chopper style bar looks funny. Is there any way to fasten it to the fork crown?
Those are actually cruiser handlebars :p But yes, it's not ideal. Under seat steering (USS) requires some extra equipment (tie rod and some sort of frame interface). If you're close enough (and have the physical space) to the fork, you can hard mount a USS handlebar - but that will be very uncomfortable if you're too far away :(
My wife doesn't allow any more bikes in the house but I think I could build this so that she doesn't realize what it is until it is too late...
Just say it's not a bike -- it's a 'bent :p
