Cheap Solar Fridge
 by cruzer28
Featured
This instructable is being entered in the Green Tech Contest so please vote.
This solar fridge is a simple and quick diy project. The reason I decided to build it was because the fridge in your house takes up a ton of energy.  This fridge is so cheap and reliable that it can be used in 3rd world countries.  It takes about 15 to 30 minutes to complete and it only cost around $15 dollars.
Here is what you need
1 large clay flower pot
1 small clay flower pot
 sand  (I used about 1/4 of a bag)
 towel
 water
 clay or plumbers putty   (only needed if there is a whole in the bottom of the pot)
Step 1: Filling up the holes
The first step is to see if you have a hole at the bottom of your pot.  If there is not a hole then you can skip this step.  If there is a hole then take your clay or putty and firmly press it into the hole and cover it.  Make sure there is no gaps for water to leak out.
Step 4: Time to put the water in
Pour water into sand to saturate it completely.  Once the water begins welling up instead of soaking in, you can stop.
Step 6: Almost done
Now you have to soak the towel and place it over the top of the pots.
Step 7: Usage of your fridge
Make  sure you put your fridge in a shaded place.  Also return once or twice a day and refill the sand with water and dampen the towel.
Step 8: How it works
The action that allows it to stay cool is the evaporation of the water surrounding the smaller pot.  As the water evaporates, heat draws out from the smaller pot, keeping the contents inside much cooler the the surrounding environment.
1-40 of 101Next »
ragtimelil says: Apr 16, 2013. 3:09 PM
I tried this and did not have success. I think it works in a dry climate but not in a humid one.
bcavaciuti says: Oct 21, 2012. 8:23 AM
you could fill the bottom holes with clay mixed with fibres(grass/rope/anything fibrous to hold its strength) this is for 3rd world countries or any people that dont have putty :)
gsteele says: Oct 2, 2012. 8:12 AM
Very "cool" project. I am wondering if it might be easier to use a circular egg crate foam top. It would hold more water and be less messy than a wet towel. I am imagining an eye bolt through the center of the foam, with a large plastic washer and nut on the bottom side (to keep from tearing the foam and make it easy to pull off the lid)
iffee says: Jul 16, 2012. 7:23 AM
How it is solar???
martinbolton in reply to iffeeAug 14, 2012. 6:39 AM
Thats what I was thinking.
Confused with 'evaporative'
iffee in reply to martinboltonAug 15, 2012. 9:48 PM
It is evaporative not solar. Think it is night time and cooling will continue in absense of sun!!!
jeffeb3 in reply to iffeeJul 16, 2012. 2:27 PM
It's not solar. "Make sure you put your fridge in a shaded place". A better title would be "Evaporative Fridge" or "No-Electricity Fridge" or "Cheap Portable Fridge".
rimar2000 in reply to jeffeb3Jul 16, 2012. 5:03 PM
Yes, it is indirectly solar, bacouse the wind is due to sun.
fzbw9br in reply to rimar2000Jul 19, 2012. 8:34 AM
the wind is not only caused by the sun, but by pressure differences on the earth, so it could be called, an "Indirect, SolaNuclear Low Pressure EvapCooler"
AKA: InSoNuLPEC device
rimar2000 in reply to fzbw9brJul 20, 2012. 5:15 AM
Yes, you are right.
phepner in reply to rimar2000Jul 19, 2012. 6:39 AM
then it's indirectly nuclear also ... nice instructable anyway
SpikeFiend in reply to phepnerJul 19, 2012. 8:14 AM
Fossil fuels are also indirectly solar energy. ;)
Would a lid on top of the center pot help keep it cooler? Assuming the evaporation takes place in the outer pot.
rimar2000 in reply to SpikeFiendJul 20, 2012. 5:08 AM
Both you are right.
iffee says: Aug 14, 2012. 9:25 PM
More interesting material can be found if you seach in google images with the following "refrigeration without electricity"
Be sure to seach in google images.
spinlite says: Jul 19, 2012. 6:34 AM
How cold does this keep the items?
jackoftheforest in reply to spinliteJul 24, 2012. 2:43 PM
I used this ancient technique when I was living in the desert, and there were a few times when ice formed. But this was only possible in the hottest, dry and windy days. And it required very regular refilling with water. But it is how nomadic people made ice in the desert ages past. Fine tuning your fabric cover, and being sure to use pots that breathe particularly well, and regular refilling, will insure cool temperatures :D
Thanks for the instructable!
static in reply to jackoftheforestJul 26, 2012. 12:25 AM
My understanding ice can be made in dry desert conditions with heat in the water radiating to the cold deep space night sky, and has been down to be done in Persia, and the American Southwest. Respectfully I can't see water cooling to freezing by mere evaporation alone during the daylight hours. When spending time out at the lake wet burlap over the ice chest helped the ice inside last longer by cooling the outside of the chests by evaporation, during the heat of the day.
1Word in reply to staticAug 14, 2012. 10:39 AM
"Respectfully I can't see water cooling to freezing by mere evaporation alone"
That's where physics comes in. Take a college level class and you'll see that it is not only possible, thanks to α = k / ρc(p), but happens often.
maewert in reply to spinliteJul 19, 2012. 12:43 PM
As the water in the towel and the output pot evaporates the pot cools down.  Think of evaporation as the 'faster' water molecules leave into the air first leaving behind the 'slower' molecules.  The slower molecules are the colder ones so the inner pot is cooled down slightly.  This depends on the humidity, since in high humidity, the water doesn't evaporate very fast so the cooling effect is less.
jackoftheforest in reply to maewertJul 24, 2012. 2:49 PM
As water evaporates it draws heat with it. With sufficient evaporation, one can reach freezing temperatures. It is the same system by which we perspire. I'm not sure what you mean by slower molecules vs faster molecules. It will only cool slightly if you live in a wet and cool place, arid and hot regions can utilize this for refrigeration, provided enough water ams optimized evaporation.
Krotas says: Aug 14, 2012. 10:28 AM
You smile at the finished project... and the project smiles back (note: first picture in the introduction page).
Bioruffo says: Jul 24, 2012. 8:08 AM
This is called a "zeer pot":
http://en.wikipedia.org/wiki/Zeer_pot
databoy says: Jul 22, 2012. 1:03 AM
Very inefficient when compared to the Coolgardie Safe.
Wikipedia:
The Coolgardie Safe is a low-tech refrigeration unit which uses the heat transfer which occurs during evaporation of water. It was named after the place where it was invented — the small mining town of Coolgardie, Western Australia, near Kalgoorlie-Boulder.
Coolgardie was the site of a gold rush in the early 1890s, prior to the Kalgoorlie-Boulder gold rush.
For the prospectors who had rushed here to find their fortune, one challenge was to extend the life of their perishable foods — hence the invention of the Coolgardie safe.
The safe was invented in the late 1890s by Arthur Patrick McCormick, who used the same principle as explorers and travellers in the Outback used to cool their canvas water bags: when the canvas bag is wet the fibres expand and it holds water. Some water seeps out and evaporates, especially if it is in a breeze, cooling the stored water.
This technology is commonly thought to have been adopted by explorer and scientist Sir Thomas Livingstone Mitchell, who had observed the way some Aborigines used kangaroo skins to carry water.
Principles of operation.
The Coolgardie Safe was made of wire mesh, hessian, a wooden frame and had a galvanised iron tray on top. The galvanised iron tray was filled with water. The hessian bag was hung over the side with one of the ends in the tray to soak up the water.
Gradually the hessian bag would get wet. When a breeze came it would go through the wet bag and evaporate the water. This would cool the air inside the safe, and in turn cool the food stored in the safe. This cooling is due to the water in the hessian needing energy to change state and evaporate. This energy is taken from the interior of the safe (metal mesh), thus making the interior cooler. There is a metal tray below the safe to catch excess water from the hessian.
It was usually placed on a veranda where there was a breeze. The Coolgardie safe was a common household item in Australia until the mid-twentieth century. Safes could be purchased ready-made or easily constructed at home.
Ole bally in reply to databoyJul 22, 2012. 11:46 PM
Dunno who invented it, but the 'upgrade' to your Coolgardies cooler was one we had when I was little and living off the grid! The fridge was made of panels of brandering wood and rabbit mesh filled with charcoal. The tray on the top had tiny holes in the rim at the bottom and a piece of cotton shoe lace was pulled through it to act as a wick. The wicks led onto the top of the charcoal panels.The try filled with water would then slowly seep through the charcoal panel and the wind / air flow would cool it!
The tray needed filling once a day or so ...held about 50 liters of water I think!
The charcoal stopped any odours too!
erdbewohner says: Jul 19, 2012. 3:43 PM
I thought about cooling my mobile home by running a perforated garden hose over the roof and pump water (from my rain barrel) to mist the roof for a certain time ( i would have to figure out the timing). The problem is that I could not find a pump yet what automatically shuts off when the water runs out. I have this on my mind since several years. (Since we have very hot summers here in Kentucky and the A/C would not run a lot less then it does) If anybody knows where to get the right pump, please post on here.
espdp2 in reply to erdbewohnerJul 20, 2012. 5:41 PM
Rather than a sump pump or "toilet float" setup as most are suggesting, you want to take a look at the siphon system from this gardening 'ible - http://www.instructables.com/id/Vermiponic-Garden/ . It will fill up more quickly on sunny days when you need more cooling, and it won't run at night when you don't need it so much.
You will need to elevate a quantity of water above your roof on a tower next to your roof (I wouldn't put it actually *on* the roof) and find a source of water (your rain barrel on the ground). Install a solar pump with sufficient head to lift it to the upper tank. When your siphon system starts working, it will drain until the tank empties and the siphon breaks, and your solar pump will continue to putter along to refill it.
This would work GREAT with a grass roofed house!
denswei in reply to espdp2Jul 22, 2012. 8:52 PM
A grass roof would be good in several ways: the dirt layer as insulation & thermal mass, and the evaporative cooling as the grass transpires water. Also, the shade of the grass (keeping direct sunlight off the soil).
Ole bally in reply to erdbewohnerJul 20, 2012. 3:29 AM
A boating bilge pump would work! Or any pump that you can attach a 'float switch' to! Ask at yr local boating store or irrigation supply store!
Daveallnight in reply to erdbewohnerJul 19, 2012. 9:10 PM
try a sump pump (with a float)
dalesql in reply to erdbewohnerJul 19, 2012. 8:09 PM
Get a sump pump with a float switch. feed that power from your timer. If the water level is too low, the pump will not turn on. About 80 bucks at the orange depot when I bought one a couple years ago.
scoutmaster197 in reply to erdbewohnerJul 19, 2012. 7:21 PM
you could use the float switch off a sump pump to control the pump or a well control switch the has a low pressure cut-off
firewoods in reply to erdbewohnerJul 19, 2012. 6:00 PM
this is called 'latent evaporative cooling' and is very effective. if you go to knowledgepublications.com, there's a book called 'How to Really Save Money and Energy in Cooling Your Home by George S Barton. detailed plans, the science behind it, etc. good stuff!
RichardBronosky in reply to erdbewohnerJul 19, 2012. 3:57 PM
Google "float switch"
iffee says: Jul 16, 2012. 7:21 AM
It works better in dry weather.
kc8hps in reply to iffeeJul 16, 2012. 11:39 AM
I'm sure solar doe not play into this equation. We are talking here about evaporation cooling.
YES you are correct this will function in more efficiently in dry climates.
The real model here resembles how a swamp cooler functions.
Swamp coolers as most of you know do not work in humid climates, just like refrigeration air conditioning is less efficient in dry climates.
denswei in reply to kc8hpsJul 19, 2012. 1:58 PM
I've wondered why more refrigeration AC systems don't gain some of the efficiencies of evaporation cooling by spraying cooling water over the compressor coils. It seems like window units reuse the condensate from the evaporator coils to haphazardly splash onto the compressor coils, but I haven't seen it done for other domestic systems.
The only problems I can see is that using tap water will cause mineral deposits on the condenser coils, while reusing the clean condensate could be complicated if there are separate evaporator and condenser units (since it would have to be pumped)
chuckyd in reply to densweiJul 22, 2012. 12:58 PM
Water cooling is not efficient for home cooling. However, evaporative coolers are used for commercial and industrial sized cooling.
denswei in reply to chuckydJul 22, 2012. 5:33 PM
??? non-sequitur...
(removed by author or community request)
chuckyd in reply to densweiJul 22, 2012. 7:52 PM
Do you even know what "non-sequitur" means?
1-40 of 101Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
