3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap and Easy Passive Solar Water Heater for your Home. ($300)
video Cheap and Easy Passive Solar Water Heater for your Home. ($300)
Heat your water for free with a solar water heater.  This $300 DIY solar water heater system even includes an electric backup water heater for cloudy days.  It heats water to 135F (55C) on sunny days in a 80 gallon (310 liter) tank - and there are no moving parts - it relies in a thermosyphon to circulate the water.
http://www.myfixlog.com/fix.php?fid=1
This heater uses PVC instead of copper.  PVC has a much lower thermal conductivity than PVC does, however there are a few ways to over come this weakness.
One way to I increased the efficiency was to use old florescent light bulbs as sleeves over the PVC pipe to act as a double glazing.  This helps insulate the PVC and increases the efficiency of the heater.  I also insulated the PVC connections to help shield them from the intense heat of sunlight.
The other way I increased efficient was increasing the surface area.  Since PVC is cheap it did not cost much to run more pipes that would be exposed to the sun.
 I also installed an automatic electric backup heater for $30.  It is a bucket heater that turns on at 80 degrees and off at 110.  Click on the link above to see more about that.
11 comments
Apr 29, 2012. 5:58 PMjumpup_dnb_dj says:
PVC has a much lower thermal conductivity than PVC does??????????? I believe that needs to be changed. Otherwise a great instructable!!!!!
Apr 25, 2011. 5:29 PMgreenspider says:
Jake, you're on the right track so far, this is good re-purposing and should work nicely.
I am concerned with what you did with the "dust" you removed from those fluorescent bulbs.
That dust contains Mercury.
You do not want to breath it when you clean out the bulbs, AND you want to dispose of it PROPERLY.
This may make it more difficult, but you, the water you drink, and the air you breathe will thank you for it.
Feb 8, 2011. 7:44 AM13blue says:
This is the best explanation of a passive solar water heater I've ever seen. Thanks for taking the time to do the project and the video.
Jan 3, 2011. 9:16 AMsparks says:
Great instructable, thanks for posting it. Especially like the repurposing of the Fluorescent tubes.
Apr 12, 2010. 11:46 AMresago says:
PVC has a low tolerance to UV, unfortunately.
I would cover the tubes with a black tarp and let the UV destroy that, instead of the pipes. then all is good.
Dec 28, 2010. 5:26 PMDudeyowuzup says:
Could I cover the pvc with Aluminum Foil and spray paint the foil black with high-heat flat black spraypaint? Would that protect it from UV while increasing the heat absorbed?
Dec 29, 2010. 12:45 PMresago says:
yeah, that should work fine.
Aug 23, 2010. 4:41 PMnfarrow says:
thanks for the CC on the video. really helps out with people like myself at working tiring to be sneaky and check out instructables
Jul 4, 2010. 6:55 AMerik_mccray says:
Wow, now thats making the most of whats at hand. You may like to check out a guy name William Kamkwamba if you haven't heard of him all ready. You two seam to think alike.
Mar 14, 2010. 12:44 PMfreak13th says:
good instructable and a good way to go green
the "dust" in the glass tubes is toxic as it has mercury in it. you and the readers should know that if they don't already.
Mar 10, 2010. 1:02 PMoakironworker says:
Great video explained everthing very well
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:jaketeater
