3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Water Sprinkler.
Watering your garden should preferably be done with rain water. However, sometimes using tap water is unavoidable. In such a case one should, as with all natural resources, be efficient and sensible.
Ever noticed how a small pinch hole in your garden hose is capable of wetting a large area?
Many commercial sprinklers have 2 things in common: they are expensive and not very efficient. They seem to be designed with the idea of getting a lot of water in the air hoping it will land somewhere where water is required.
This device relies more on pressure than on size, creating a fine sheet of water. This I'ble will show you how to build this very cheap and simple lawn sprinkler and it will show you how to customize you sprinkler by going into some patterns.
If you like my idea, don't forget to vote for me in the "Garden Contest".
Step 1How to make it.
How to make it.
It's quite simple: a pipe and two legs. Due to the round legs, it slides quite easily over your lawn when you pull the hose (so you don't get wet).
What you need.
An Aluminium tube (OD 10 mm)
2 PVC pipes
Hose clamp
How it is made.
Drill a 10 mm hole trough both PVC pipes.
Insert the Aluminium pipe through the PVC pipes.
Saw a notch (more about patterns in the next step).
Plug the end of the pipe.
Connect hose and clamp.
You can rotate the tube in its legs to aim the water curtain at a specific region. Be careful not to point it downward too much or you end up soaking the earth beneath it.
You can make this fairly long (or short) to meet your requirements. Be aware that over a distance you gradually loose pressure. Secondly, very long ones can become weak (you should add an extra PVC "leg" in the middle).
10 comments
May 31, 2010. 12:16 AMbeackmaniax says:
Good work, really nice instructable, maybe using less presure you dont need to modify it, five stars really !
May 25, 2010. 10:29 AMmeddler says:
I bet if you put some 5 ton epoxy on the wood plug and then a dollop on the end after you put it in. It would never come out.
May 15, 2010. 9:23 PMToga_Dan says:
 3 alternatives for the pipe end-
Mash the end closed, and fold it over. Possibly with some caulk.
Solder a cap onto the end of the copper tube. This requires a torch, flux, solder. That's a way a plumber would do it.
Mash the end closed, solder it.
May 13, 2010. 3:35 PMNinzerbean says:
 Wonderful, but how do you plug the end of the pipe?
May 14, 2010. 3:57 AMNinzerbean says:
 Can you show us? I never thought about making my own sprinkler, this is just so great,
May 14, 2010. 11:50 AMNinzerbean says:
 Oh, that's what you meant - we call those plastic anchors for drywall.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:bertus52x11
Check out The CameraClip, a commercial spin-off of one of my I'bles at www.cameraclip.eu OR in the Instructables Store!
