Remove these ads by
Signing UpStep 1Making the Grindstone
1: Take some river clay or some other kind of cheap clay
2: Make a bar of it.
3: Make grooves in it over the whole length, so that it's the half cross-section of the object you want.
4: Bake it. Usually with river clay you let it wait to dry for some weeks, and then bake it, when all water is out of it and it can't break. But you can also just start the oven not really warm, and after half an hour put it on it's max. Then there's a little chance that the whole things breaks in two, but that's no big problem, you can just glue the parts together. This is just a grindstone, I doesn't need to be esthetically perfect.
5: Take a piece of sandpaper the size of the grindstone.
6: Glue it on it. You may need to push in the grooves a lot. This is easier when you have wider grooves. don't use an extremely good glue, because you probably need to replace the piece of sandpaper by another one after some grinding.
26
comments
Add Comment
merijnvw (author)
says:
merijnvw (author)
says:
bowmaster
says:
merijnvw (author)
says:
yokozuna
says:
merijnvw (author)
says:
merijnvw (author)
says:
skunkbait
says:
Weissensteinburg
says:
Add Comment
