Cheap Airsoft Smart Charger.
Introduction: Cheap Airsoft Smart Charger.
In this Instructable I will show you how to make a cheap smart charger for your airsoft gun.
Step 1: What You Need
What you will need.
1 regular factory airsoft charger. (free, comes with gun)
1 cheap wal-mart garden timer. (around 5-10 dollars)
Step 2: Making the Charger
Now all you do is plug the airsoft charger into the timer and you are done.
Step 3: Using the Charger
To use the charger you just set the time you want the timer to shut off and plug it in. No more overcharged batteries!
(for some timers you can even set the hours it will run and the time it shuts off)
If you are unsure on how long to charge your battery then keep reading.
Step 4: How Long to Charge the Battery
If you don't know how long to charge your battery then all you have to do is look on your charger and there should be a label. On this label is listed the chargers info. All you need is the "output" section. To figure out the charging time just divide your battery's mAh capacity by the chargers output mAh capacity. Then multiply that by 1.4 for NiCad batteries or 1.5 for NiMh batteries.
For example my chargers output is 250 mAh and by battery (NiCad) is 1200 mAh so it should look like this.
1200/250 X 1.4= 6.72
So I charge my battery about 6-7 hours or until it gets hot to the touch.
Always stop charging your battery when it gets hot to the touch!
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Cheap in the short run but i wouldn't rely on it.
    Great idea! also spend like $5 more and get an extra trickle charger, because there´s also an instructable on how to make a battery drainer out of that and an LED light!
    This is cool, but i'd like to point out that your formula assumes a completly dead battery. Ussualy a battery will stop pulling gears when its still got a fairly good deal of charge in it, so you gotta remember to dicharge it completely before charging it for the calculated charge time.(of course you should anyway, especialy for NiCd.)
    I have a timer! Why did I never think of this? Thanks!
    its a good idea but i would spring for the extra 30 bucks for a reall smart charger it will charge your battery in under 2.5 hours and will help it retain its charge longer because you control how much miliamps go through
    tha and the wonderful "discharge feature"
    Thx! and nice idea! very bright and cheap!
